SNR Reset
FIXED- Subscribe to RSS Feed
- Re: SNR Reset
06-07-2021 4:35 PM - edited 06-07-2021 4:46 PM
Hi There,
Would someone be able to reset my line please? It appears to be stuck at 8 dB, whereas it previously performed well at 6dB.
Cheers,
Jonny
Fixed! Go to the fix.
Re: SNR Reset
06-07-2021 5:04 PM
@jonnymccni There may be a reason why the SNR has increased, but this will need PN staff intervention either way.
Re: SNR Reset
06-07-2021 5:06 PM
It will be at 8dB for a good reason - that is not a standard SNRM target - they are set in 3dB increments, typically 6dB or 9dB on a slightly degraded line. Interstitial values suggest that either a line is speed banded or there has been a change in noise levels since the last resync.
Have there been problems on your line?
What do the router stats look like?
What is the SNRM immediately after restarting the router?
Re: SNR Reset
06-07-2021 6:43 PM
Re: SNR Reset
on 06-07-2021 6:50 PM - last edited on 07-07-2021 8:13 PM by Mav
I think my stats should be attached here.... My SNR was 3dB at one stage and was working really well. But I'm a fair distance and understand conditions can change.
Thanks for help,
Jonny
Re: SNR Reset
06-07-2021 7:24 PM
Moderators Note
This topic has been moved from ADSL Broadband to Fibre
Re: SNR Reset
06-07-2021 7:55 PM
Hi @jonnymccni,
I've had a look into this one today and from what I can see on my end, everything is currently performing as we'd expect. When you'd mentioned that there'd been stormy weather in the area and that this had affected the connection, I was concerned another fault may have developed, however my line tests haven't picked up anything out of the ordinary this evening. That being said, it's worth keeping an eye on from your end of things and if it does seem to worsen over the next few days, please don't hesitate to get back in touch so that we may investigate further.
Re: SNR Reset
07-07-2021 4:53 PM
Hi Alex, thanks for checking, I'll keep an eye. Its just annoying that it was connecting at over 10 and now its down to just above 8, so i know the line was capable of better. The last Openreach engineers told me that they could see about 13 on the line, and suggested that i shouldn't be loosing as much through the router, and that's when i was connected at over 10.
Thanks again,
Jonny
Re: SNR Reset
07-07-2021 5:34 PM
Hi @jonnymccni,
It occurs to me that it's worth testing with another router, though unfortunately the current router is out of warranty so I wouldn't be able to send a new one out at this time. Do you happen to have a spare router to hand for testing purposes? (Please be aware that this is simply to test if there's any noticeable differences in performance and that we still can't guarantee it will improve)
Re: SNR Reset
15-07-2021 10:24 AM
15-07-2021 11:09 AM
Hi @jonnymccni,
I'm sorry to hear that there's been no improvement. I've placed a request to reset the DLM on your line which should hopefully fix this in the coming days. Should any further problems persist then please drop another message onto this thread and we'll be happy to pick this back up for review as soon as possible.
Re: SNR Reset
13-08-2021 11:36 AM
Thanks very much, that seems to have settled things out OK.
Re: SNR Reset
13-08-2021 3:02 PM
I'm glad to hear that looks to have sorted the connection out for you @jonnymccni. If there's anything we can help you with moving forwards then please don't hesitate getting back in touch.
