Router keeps dropping connection engineer says nothing wrong
orangeman
Following on from this thread
https://community.plus.net/t5/Fibre-Broadband/Router-keeps-dropping-connection-engineer-says-nothing...
I'm having massive disconnection issues with my line for a long while now. I hoped moving ISP would fix this issue but i still have the issue. It cannot be router related as this has changed as well as all cables A previous engineer changed my face plate for a new one. I know i have only just joined Plusnet and ive given it 1 week to sort itself out which as you can see it has not as well as previously having issues with my last ISP. Id like to know what can be done about an intermittent connection please as previously when an engineer has come he has said nothing is wrong and everything is fine "which it would do when its working its working but doesn't solving my constant disconnection issues"
Disconnections -
5th September
<02:45:11> Connection to server lost
6th September
<05:15:11> Connection to server lost
<13:32:33> Connection to server lost
<15:29:55> Connection to server lost
<16:41:06> Connection to server lost
<19:59:11> Connection to server lost
7th September
<17:13:44> Connection to server lost
8th September
<00:03:47> Connection to server lost
<02:48:09> Connection to server lost
<20:38:16> Connection to server lost
9th September
<03:53:23> Connection to server lost
<20:45:13> Connection to server lost
<23:12:25> Connection to server lost
10th september
<04:05:07> Connection to server lost
<16:12:00> Connection to server lost
<17:23:39> Connection to server lost
<17:55:36> Connection to server lost
11th September
<13:54:47> Connection to server lost
<15:04:02> Connection to server lost
<17:22:57> Connection to server lost
23 REPLIES 23
Fixes: 1,484
Re: Router keeps dropping connection engineer says nothing wrong
Moderators Note.
Post released from spam quarantine
RandallFlagg
Fixes: 75
Hi @orangeman
Thanks for getting in touch.
I can see the drops that you're referring to, so I'm surprised historical engineers have missed them.
I can also see that you've started to raise a fault via the online portal - could you please complete this and give us a nudge when you've done so, so that we can escalate this to our suppliers?
Best wishes,
Dave
orangeman
Will do soon.
I've stopped the form as i have no home phone to test as well as the line speed has reduced to its lowest point yet so wondering if it will become stable "wishful thinking i think" but wanted to get a cheap home phone to help with questions.
Will post here when i precede further
orangeman
2 more disconnects added to 1st post, as will all other disconnects to keep an online record.
Fault raised
Fixes: 1,601
Thanks for raising the fault and the detail.
I've updated your fault ticket which you can view and reply to Here.
Essentially we'd likely need to arrange another engineer visit to further investigate this, but if you can give us a nudge over here once you've replied to the ticket we'll be happy to pick it up
orangeman
Replied
I have a master socket 5c and cannot see a test socket after i take off the faceplate?
Fixes: 1,601
The test socket should be in the centre when you remove the faceplate.
If you're unable to to find it still, could you post up a photo of the socket?
orangeman
Ok thanks, I'm use to it having 2 sockets like before on my old one. This one just has 1 socket i take it which is not labelled like the last one.
orangeman
Microfilter and in test socket now
more d/c cant edit 1st post
11th September
<19:28:22> Connection to server lost
12th September
<04:43:24> Connection to server lost
<07:46:32> Connection to server lost
<07:53:26> Connection to server lost - Changed over to test socket with filter
orangeman
can you also reopen my fault as its saying its closed by me?
orangeman
can anyone do the above and reopen my fault please?
also 2 d/c's after using test socket
12 September
<11:14:23> Connection to server lost
<13:06:29> Connection to server lost
Fixes: 1,601
Apologies for the delayed response.
Unfortunately we can't re-open the ticket, so I'd recommend creating a new one at http://faults.plus.net referencing ticket 182488147 in the box at the end.
Don't worry about typing extra notes for us, as yesterday I copied and pasted the notes you gave us while filling out the troubleshooter, to the ticket itself so we can see them still.
orangeman
Thanks made a new one
12th September
<18:18:48> Connection to server lost - off till <18:28:18>
<18:29:12> Connection to server lost
<18:45:12> Connection to server lost
<20:10:48> Connection to server lost
orangeman
Can someone please pick this up and book me an engineer?
12th September
<21:18:46> Connection to server lost
13th September
<03:22:42> Connection to server lost
<03:36:16> Connection to server lost
<09:39:24> Connection to server lost
