Reset
col6
Reset
Hi Plusnet my speed has dropped from 75mb to 28mb again this will be due to stop start of router
can you sort me out thanks ?
Fixes: 17
Re: Reset
How many times did you reboot your router to manage that?
As far as I know, the FTTC DLM cannot be reset without an engineer visit.
Can you post the line stats from your modem/router?
Fixes: 162
Re: Reset
I'm afraid we can't reset profiles on a fibre line, however looking at your connection it's back in sync at a higher speed again. Are you still having issues?
 Chris Parr
 Plusnet Staff
col6
Re: Reset
All sorted now thank you not sure what it was just fixed itself ,,,,, Feedback for Plusnet your customer service is second to non keep up the great work guys Brilliant .
