Repetitive drop out - ICMP blocks
- Repetitive drop out - ICMP blocks
- « Previous
- 1
- 2
- Next »
Re: Repetitive drop out - ICMP blocks
30-06-2020 12:22 AM
Hi im getting exactly the same, its very annoying!!
I cant change router like you did....anything else can be done.?
30-06-2020 7:46 AM
Seems as though a BT hub 6 goes for £30ish on eBay and changing the settings to enable it to run PlusNet is not particularly difficult.
I would agree though, it is extremely frustrating.
20-07-2020 5:26 PM
I am having the same problem: everytime I have a new internet request, I wait a minute or two before acessing a content, Once the connection is made it's a bit better until I change page. I've tried to ping a server (google) and ping does nothing for a few minute and then return very good value (9ms). So it looks like it's an "address resolve" issue of some sort.
I tried to troubleshoot from the router but the it tells me that my connection is good (!). Thankfully it then showed me the log which displayed things like that:
OUT: BLOCK [7] ICMP replay (ICMP type 3 code 1 146.198.114.10->216.58.210.42 on ppp3)
Could that be indicative of a problem?
This seems new from this week, although I was away from Friday morning so not sure what happenend at the weekend. This happens with my PC (Win 10) connected by ethernet to the router 1m away. All the time, the router's light stays solid blue.
I am working from home so this is a disaster. The video calls are looking like I am in the middle of the Australian Outback, cutting for minute and then resuming for seconds.
Can anyone help? PN staff?
09-09-2020 1:19 PM
I too am getting the same problem. I don't really want to replace hardware for this issue.
Very annoying, it's only started in the past 24 hours though.
13-02-2021 2:57 PM
Navigate to advanced settings on the router, go to firewall, upnp. Turn off 'extended upnp security'.
- « Previous
- 1
- 2
- Next »
