Recommended router for fiber broadband
- Re: Recommended router for fiber broadband
- « Previous
- 1
- 2
- Next »
16-08-2018 9:40 AM - edited 16-08-2018 9:42 AM
Hardware Overview of the Modem
Router
This manual describes the following models:
• NETGEAR® N600 WiFi DSL Modem Router, Model D3600.
Provides two radios with WiFi connection speeds up to1 300 Mbps per radio for a total
aggregate throughput of 600 Mbps. The 2.4 GHz radio supports 802.11n and the 5 GHz
radio supports 802.11na.
• NETGEAR® AC750 WiFi DSL Modem Router, Model D6000.
Provides two radios with WiFi connection speeds up to1 300 Mbps for the 2.4 GHz radio
and up to1 433 Mbps for the 5 GHz radio for a total aggregate throughput of 750 Mbps.
The 2.4 GHz radio supports 802.11n and the 5 GHz radio supports 802.11ac.
For each model, both radios can be active simultaneously.These models are compatible with most major DSL Internet service providers and also supports cable or fiber Internet service.
16-08-2018 9:41 AM
According to the manual on the website the Netgear AC750 Modem Router does work with VDSL FTTC fiber and it does what I need it to do.
What it doesn't say , is that to work with Fibre , you will need a Fibre modem as well
16-08-2018 9:45 AM - edited 16-08-2018 9:46 AM
I'm confused at what you say because it is a modem router, so why would I need a separate modem if it is already a modem router?
Also it's got exactly the same on the back as the Hub one which has 4 Ethernet ports and it also says ADSL like the Hub one does.
Can you send me the link to information that says it doesn't work with VDSL please?
16-08-2018 9:47 AM - edited 16-08-2018 9:51 AM
Because some modems are ADSL/VDSL and some are ADSL only.
To clarify your edit; some will say they work perfectly well with fibre as separate VDSL or cable modems were a thing with BT and Virgin.
16-08-2018 9:59 AM
I've just seen the cost, not cheap and am sure but you need a VDSL router.
This link, although it seems to reference a US ISP and not PlusNet (look at the last question), would imply it doesn't.
So you would need two boxes plugged in. Don't understand why it is classed as a modem when it appears to be a router only.
16-08-2018 10:03 AM
It does have a modem built in, but its an ADSL modem and not a VDSL modem.
16-08-2018 10:07 AM - edited 16-08-2018 10:08 AM
Thanks @hangar18, so it's no good for the OP then?
You will need to look for something else, sure someone here can recommend something.
16-08-2018 10:15 AM - edited 16-08-2018 10:15 AM
16-08-2018 10:19 AM
https://www.argos.co.uk/product/5728882
It does say it's VDSL though.
16-08-2018 10:38 AM
The Hub One doesn't present any inherent security risks IMO, and the protection offered by MAC filtering is questionable at best. It's trivial to spoof MAC addresses.
16-08-2018 10:39 AM
That is a very basic router, with slow WiFi speeds, and does it have the features you are looking for?
16-08-2018 10:59 AM
Thanks @bobpullen
I didn't know MAC cloning was that easy, never have tried it.
The thing with that is, you'd need someone determined to be able to do it, wouldn't they need to know a valid authorised MAC to change it to?
See what you mean about the lack of 5Ghz signal. It may not cause a wireless problem, but it could.
16-08-2018 11:42 AM
Why not just accept that if you want a new router with the additional functions you desire for the budget you have then at the very best you will end up with a router with performance and features that the vast majority of us consider important inferior to the Hub One. Your alternative is to see what's available second hand.
I'm sure that I'm not alone in thinking that you would be far better off forgetting about your wish list as the risk of your WiFi security being breached, especially if you set a strong password, is very low.
16-08-2018 11:50 AM - edited 16-08-2018 11:55 AM
No
I had better security options on a 7 year old Netgear router when I was on ADSL just 2 days ago so it's NOT unreasonable to want the same security settings I'm used to is it!
Also it's abundantly clear the security is rubbish on the Hub one anyway as someone from Plusnet just yesterday could easily access the Hub one and reset everything back to default including the very strong WiFi password I'd chosen, if Plusnet can do it in seconds which is all it took them! Then anyone can!
I'll simply have to save up more money and pay top whack for a decent VDSL modem router that will provide me with the features I expect to have purely based on the fact that I could get those features on a 7 year old modem router then I should be able to have the exact same on a much newer modem router, clearly not with the Hub one though...
Oh well, I'll start saving again for what I want.
Also just to clarify with an access list that absolutely guarantees nobody can access my internet as only allowed devices can connect and even if devices not allowed were to get the wireless key it would be useless to them as they'd simply still be denied access because they're not in the access list.
And that's the type of security I want and the security I'm used to, so just because you don't think it's likely with a strong password that it will be breached, I simply don't want to give them a chance.
Obviously security is more important to me than it is for you.
16-08-2018 6:59 PM
The latest firmware release notes for the Netgear router you have are dated 2016, so I'd question your opinion of how secure it actually is?
An access list based on MAC filtering does not *guarantee* other devices can't access your router. As mentioned previously, MAC addresses can be spoofed.
Not here to have an argument, but I fully defend any claims that the security of the Hub One is 'rubbish' or can easily lead to compromise.
- « Previous
- 1
- 2
- Next »
