Recently switched from Talktalk and think my upload bandwidth is choked down.
lomcovaks
Dear Support team,
I'm a recent newcomer to Plusnet after Talktalk leaked my personal data to a criminal gang of Indian scammers.
My fibre download speed is consistently in the 35-40 Mb/s range but my upload bandwidth is always stuck around 0.5 Mb/s.
I'm connected to the test socket of my main socket and running a Netgear R7000 Nighthawk router which I've flashed with Kong's DD-WRT firmware to put my entire home network behind my VPN - but all my speed tests are done with the VPN off.
Would it be possible if someone could kindly check and see if my upload bandwidth is being choked down as a legacy issue from Talktalk please? I suspect this may  be the case.
Many thanks.
1 REPLY
Fixes: 54
Re: Recently switched from Talktalk and think my upload bandwidth is choked down.
Don't worry there's absolutely no way another ISP could have any affect at all on your connection as you're no longer their customer.
Diagnostic tests show a potential performance fault so please report this over at http://faults.plus.net and we'll get it sorted for you.
 Adam Walker
