Re: Request GEA test
- Re: Request GEA Test
16-04-2019 4:37 PM - edited 16-04-2019 4:49 PM
Removed
16-04-2019 9:56 AM
Could I have one please ?
16-04-2019 11:13 AM - edited 16-04-2019 11:13 AM
I've provided yours below
Test Outcome | Pass |
Test Outcome Code | GTC_FTTC_SERVICE_0000 |
Description | GEA service test completed and no fault found . |
Main Fault Location | OK |
Sync Status | In Sync |
Downstream Speed | 62.8 Mbps |
Upstream Speed | 20.0 Mbps |
Appointment Required | N |
Fault Report Advised | N |
NTE Power Status | PowerOn |
Voice Line Test Result | Voice fault suspected - contact Voice CP to progress copper issue |
Bridge Tap | Not Detected |
Repetitive Electrical Impulse Noise | Not Detected |
Estimated Line Length In Metres | 405.9 |
Upstream Rate Assessment | Very Good |
Downstream Rate Assessment | Reasonable |
Interference Pattern | Not Detected |
Service Impact | No Impact Observed |
Home Wiring Problem | Not Detected |
Downstream Policing Discard Rate | 0.0 |
Customer Traffic Level | Upstream and Downstream Traffic Detected |
Technology | VDSL |
Profile Name | 0.128M-80M Downstream, Error Protection Off - 0.128M-20M Upstream, Error Protection Off |
Time Stamp | 2019-04-03T11:15:00 |
Parameters | MIN | MAX | AVG |
Down Stream Line Rate | 62.5 Mbps | 62.7 Mbps | 62.5 Mbps |
Up Stream Line Rate | 19.9 Mbps | 20.0 Mbps | 19.9 Mbps |
Up Time | 820.0 Sec | 900.0 Sec | 899.9 Sec |
Retrains | 0.0 | 1.0 | 0.0 |
Current and Last 15 Minute Bin Performance | ||
Parameters | Last Traffic Count(Upto 15 mins) | Current Traffic Count(Upto 15 mins) |
Start Time Stamp | 2019-04-16T10:48:02.695+01:00 | 2019-04-16T11:03:02.695+01:00 |
Ingress Code Violation | 0 | 0 |
Egress Code Violation | 0 | 11 |
Errored Seconds | 5 | 0 |
Severely Errored Seconds | 0 | 0 |
Unavailable Seconds | 0 | 0 |
The voice fault suspected appears to be a loop fault in your property according to our tests. Are you connected to the master socket?
16-04-2019 11:21 AM
Thanks, router is connected to the master socket with no other internal connections, I'll connect to test socket.
16-04-2019 11:25 AM
Done...
16-04-2019 11:57 AM
16-04-2019 12:07 PM
Phone removed, do you want the router disconnected ?
16-04-2019 12:48 PM
Apologies @goldenfibre for high jacking your thread.
@MatthewWheeler Can we start another thread ?
16-04-2019 3:46 PM
@Champnet I'm afraid I can't start another thread for you but you can do this yourself if you'd like.
With regards to the tests we'd need everything disconnected router included
16-04-2019 4:10 PM
Everything is disconnected.
16-04-2019 4:22 PM
16-04-2019 4:25 PM
Phone’s in, router’s still out
16-04-2019 4:47 PM
Moderators Note
Posts split and moved into new topic.
16-04-2019 4:49 PM
Thanks @dvorak
16-04-2019 5:02 PM
