Random internet connection drop outs
- Random internet connection drop outs
- « Previous
- 1
- 2
- Next »
Re: Random internet connection drop outs
16-05-2021 2:42 PM
Ah I see, you won't need a microfilter with the faceplate as that has a filter built in but to use the test socket you'll need a filter. You can use the same cable though as that'll go into the filter and in turn into the test socket.
16-05-2021 2:53 PM
That's fine, i'll give that a go
So can you see any HEC / FEC errors on this router? as the web interface does not show me that level of detail?
As i want to know if the issue is with the HG612 or if the modem in the Plusnet router is still showing errors on the line?
As if we are still getting the errors and it move to the test socket, that would suggest a wiring issue, be it internal or external
16-05-2021 3:10 PM - edited 16-05-2021 3:11 PM
No problem, diagnostics aren't showing any errors
I've attached our standard testing below:
GEA Test Detail | ||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
And advanced testing also:
The DLM stability profile you're on is the middle one (not the fastest but not the most stable) so I could increase the stability profile which while you'd likely see a small reduction in sync speed, this may resolve the drops and improve the overall performance. Let me know if you'd want me to give that a go
16-05-2021 5:06 PM
Can you cancel the OpenReach engineer for now?
I've changed the face plate with a new one and i've used a new cable from the socket to the modem
The line sync rate is showing 72 down and 20 up and a speed test is 66 down and 18 up
No errors showing now currently
I'll continue to monitor and if necessary i'll raise a new ticket.
Do you need me to update the ticket or can you do it?
16-05-2021 5:20 PM
Hello, no problem and sounds good.
From what I can see we haven't booked an engineer visit, the ticket's been passed to you awaiting for your availability for one. It'll stay open for the next 14 days before closing automatically so you can reply to the ticket in the meantime if needed.
If there are further issues feel free to post back or raise a new fault ticket at faults.plus.net (if the existing one's closed)
17-05-2021 4:36 PM
So for whatever reason my connection has been stable until around 4pm today
Also the router still shows a sync of 72 down and 20 up, however a speed test and my account shows 65 down, which is now also below the minimum guaranteed speed.
This is what started to happen last time and it took an Openreach engineer to resolve it externally to my house.
So would it be possible to have an Openreach engineer to investigate the line sync issues and stability again and also what would it take to organise having the master socket moved?
When we bought the house, the house builders decided to put it in the hallway, which does not work and we have to run the phone cable into another room. I would like the socket relocating into that other room, which also happens to be at the front of the house. Can that be arranged?
17-05-2021 5:20 PM
Thank you for your response, and I;m sorry to hear that your connection issues have continued.
I've run some tests on the line, and the drop outs are apparent on our end. I've tried to call you a moment ago to arrange an engineer appointment but have not been able to get through. Please give our Technical Support Team a call on 0800 432 0200 and we'll be more than happy to get this booked in for you.
In regards to a master socket relocation, our Provisioning Team would be able to process this for you, however a call out charge of £160.00 would need to be taken prior to arranging the appointment. If you'd like to proceed with this, please give us a call.
-Adam - Plusnet Leeds
17-05-2021 9:09 PM
Hi Adam,
In that case i'll just stick to having an engineer come and resolve the line sync / speed / error issue
£160 is a lot of money to move a socket
I'll update my existing ticket for an engineer to attend
17-05-2021 9:53 PM
Hi, for some reason it won't let me edit my previous post
I have swapped my HG612 modem for a Billion 8800NL R2
Looking at the logs, it reports the following
G.INP Mode = Disabled
G.Fast Mode = Disabled
I don't know if either of these should be enabled
My line speed is now between 57-59 Mbps for reference
17-05-2021 10:55 PM
So i have reconnected my HG612 3B modem and i certainly get a better sync, throughput is only slightly faster
i have attached a log from the modem, before the issues started, the modem was syncing at 77 down and 36 up.
- « Previous
- 1
- 2
- Next »
