Service issues in West Yorkshire
hsbc1972
Anyone has internet issues specifically since yesterday regarding slow service, dropping out and disconnects ? Prior to then everything was ok. Looking at the PN service status everything is ok, clearly not for me !
12 REPLIES 12
Aspiring Legend
Fixes: 162
Re: Service issues in West Yorkshire
@hsbc1972 Probably just you. Sight of your 'Help Desk' page from the Troubleshooting tab on your router, with any personal info redacted, would possibly be helpful.
hsbc1972
ok thanks, once I worked out how to do that I will give it a go.
RichardB
Champion
Fixes: 34
@hsbc1972
You can get stats from the hub one if you visit http://192.168.1.254 then click troubleshooting and then help desk.
Aspiring Legend
Fixes: 162
Easy - log into your router (presumably a Hub1), click the 'Troubleshooting' tab -top right, take a screenshot and edit out personal details before uploading to the topic. Picture below might help:
Fixes: 1,529
Welcome to our community forums @hsbc1972 Our service status would be for issues on the Plusnet network that affect a large number of people rather than supplier issues although I appreciate making people aware of major service outages is a good idea, it's something we can certainly take onboard.
Moving on to the issue with your service, there's no major service outages showing that's affecting your line. Looking at your connection pictured below, it's stable and testing your line is showing download speed's OK although your upload's slow but that may be down to the length of your line.
Are you using a wired or wireless connection? Also I've attached the test results below
GEA Test Detail
Circuit ID NA Service ID [redacted]
Test Outcome Pass
Main Fault Location OK
Sync Status In Sync
Downstream Speed 15.6 Mbps
Upstream Speed 0.6 Mbps
Appointment Required N
Fault Report Advised N
NTE Power Status PowerOn
Voice Line Test Result Pass
Cross Talk Not Detected
Estimated Line Length In Metres 1537.7
Upstream Rate Assessment Reasonable
Downstream Rate Assessment Reasonable
Interference Pattern Regular Interference Observed Daily
Interference Duration Longest Occurrence From21:45to04:00
Interference Location Customer Premise
Interference Observed In Days 0
Technology VDSL
DP Type External
Profile Name 0.128M-40M Downstream, Interleaving Low - 0.128M-10M Upstream, Error Protection Off
Time Stamp 2021-05-03T13:30:00
Parameters MIN MAX AVG
Down Stream Line Rate 15.0 Mbps 15.6 Mbps 15.2 Mbps
Up Stream Line Rate 0.5 Mbps 0.6 Mbps 0.6 Mbps
Up Time 762.0 Sec 900.0 Sec 899.7 Sec
Retrains 0.0 3.0 0.0
Current and Last 15 Minute Bin Performance
Parameters Last Traffic Count(Upto 15 mins) Current Traffic Count(Upto 15 mins)
Start Time Stamp 2021-05-16T13:02:49.753+01:00 2021-05-16T13:17:49.753+01:00
Ingress Code Violation 0 0
Egress Code Violation 0 0
Errored Seconds 1 0
Severely Errored Seconds 0 0
Unavailable Seconds 0 0
hsbc1972
many thanks for the info, very impressed. At TT you struggled to get a timely reply let alone that kind of information !
hsbc1972
im not the most techy person here but hopefully this may help
Aspiring Legend
Fixes: 162
Thanks for that, @hsbc1972 - exactly what I needed, but unfortunately, apart from your horrible attenuation figures(you must be a massive distance from the cab), there is nothing there that shouts out at me, in fact it all looks very reasonable.
I'm afraid all I can suggest at the moment is that you run through the 'speed issues' topic on this board, and then raise a question at faults.plus.net .
You do have an issue, but not one that has an obvious cause.
hsbc1972
@jab1  thanks for the feedback, according to BT records we are about 400m away from our cab. Not sure if they report direct distance or actual distance. We are on a small housing estate thats been here for approx 40 years and not in a remote location !
ps Having reread the info posted yesterday about my line results I see there is mention of distance of 1500+m, presume this is to the exchange rather than the cab ?
Aspiring Legend
Fixes: 162
With the 'reported' attenuation, your cables must go a long way round, then.
hsbc1972
who knows what they did 40+ years ago.
Aspiring Legend
Fixes: 162
Not me! 😀
