Plusnet fibre broadband does not cope with uploads and will disconnect you...
- Plusnet fibre broadband does not cope with uploads...
Re: Plusnet fibre broadband does not cope with uploads and will disconnect you...
08-02-2017 1:24 PM
@PKblue wrote:
Since this post I now use some Android devices at home and the broadband dropout is occurring sometimes again, so hopefully you can apply another patch/fix.
Your line dropped twice, yesterday afternoon/early evening. That excepted, it's been uninterrupted for ~20 days. The use of Android devices should have zero bearing on the problem.
@mcjizja, changes applied to your device too.
on 08-02-2017 1:30 PM - last edited on 08-02-2017 8:12 PM by Mav
I have only been using Android devices for a few days really, so I thought it was relevant that the issue is now occurring again. Other people have said it may relate to Google Drive, which is being used by me now. Hopefully the dropouts won't be a regular thing.
PK
Moderator's note by Mike (Mav): Full quote of preceding post removed as per Forum rules.
08-02-2017 1:38 PM
08-02-2017 2:04 PM - edited 08-02-2017 3:02 PM
@bobpullen Is that the case with all versions of the firmware or 226 only?
If the latter is true, is there any way of preventing it (226) from loading onto the Hub One?
Edit: Hub One out of the box has software version 4.7.5.1.83.8.217.1.1
08-02-2017 2:51 PM
Thanks @bobpullen, looking at that chart, it appears you have fixed my issue. Good work and thank you! 👏🏼👏🏼👏🏼👏🏼👏🏼👏🏼👏🏼👏🏼👏🏼👏🏼
08-02-2017 3:04 PM
Thanks for that @bobpullen
Any chance of a graph detailing my drop outs? Similar to what you provided @adamyaffe with?
08-02-2017 5:54 PM - edited 09-02-2017 4:54 PM
@figgley wrote:
... is there any way of preventing it (226) from loading onto the Hub One?
.226 is coming straight out of the warehouse now, so probably not a great deal of merit in this.
Can't get onto the corporate network where that graph generator lives at present but here's your recent RADIUS logs:
Session Started | Session Ended | Session Duration 02:05 07/Feb/2017 N/A One Day, 15:45:28 (on going) 01:52 07/Feb/2017 02:05 07/Feb/2017 0:12:25 01:47 07/Feb/2017 01:52 07/Feb/2017 0:4:31 01:43 07/Feb/2017 01:46 07/Feb/2017 0:3:31 00:46 07/Feb/2017 01:42 07/Feb/2017 0:56:4 00:35 07/Feb/2017 00:46 07/Feb/2017 0:11:5 00:29 07/Feb/2017 00:34 07/Feb/2017 0:5:26 00:22 07/Feb/2017 00:28 07/Feb/2017 0:5:35 00:18 07/Feb/2017 00:22 07/Feb/2017 0:3:40 00:14 07/Feb/2017 00:17 07/Feb/2017 0:3:27 00:10 07/Feb/2017 00:13 07/Feb/2017 0:3:29 00:06 07/Feb/2017 00:09 07/Feb/2017 0:3:23 23:53 06/Feb/2017 00:05 07/Feb/2017 0:12:0 23:49 06/Feb/2017 23:53 06/Feb/2017 0:3:48 23:42 06/Feb/2017 23:48 06/Feb/2017 0:6:34 23:32 06/Feb/2017 23:41 06/Feb/2017 0:8:46 23:10 06/Feb/2017 23:32 06/Feb/2017 0:21:14 03:54 06/Feb/2017 23:10 06/Feb/2017 19:15:28
08-02-2017 6:30 PM
@bobpullen Thanks for the response. The Hub One that arrived last Saturday must be older stock then.
I'll gently hassle you for that "magic" fix after I'm up and running.
Just waiting on Hope 'n' Reach for the connection now.
Cheers.
10-02-2017 11:53 AM
I found this thread due to frequent disconnections - any chance the fix can be applied for me as well?
Many thanks.
10-02-2017 6:34 PM
We moved home, a few weeks ago, and since the broadband was connected we seem to have this problem although it is getting more frequent by the day. Put a call in last week and it was monitored over last weekend, a new router was ordered and installed on Tuesday and it seemed to fix the problem for several hours but then it came back again with a vengeance, now dropping out several times an hour. Talked to support yesterday and was talked through reconfiguring the router and told about uploads caused by using iCloud. Still not working this morning so I have disconnected iCloud from my mac, iPad, and iPhone so I assume there will no longer be upload problems? Unfortunately, this has not helped at all and I am still getting dropouts several times an hour.
Any help really appreciated.
10-02-2017 7:47 PM
Assuming you're using a Plusnet Hub One....(y/n)? On a fibre connection.
Click this link to the hub UI - direct link - in the drop down menu select WAN and read through the pages.
If you see the following, as this appears to be what to look for, you will need the temporary fix applied to your router.
(copied from mine for clarity)
14:36:07, 22 Jan. | (1450093.780000) PPPoE is down after 3452 minutes uptime [Disconnected] |
14:36:04, 22 Jan. | (1450091.230000) PPP LCP Send Termination Request [PPPoE PADT received] |
10-02-2017 10:06 PM
PLUSNET - when is this going to be rectified. You are currently offering a substandard service.
Again this evening;
17:28:42, 10 Feb. (4740505.950000) PTM over DSL is down after 1095 minutes uptime 17:28:42, 10 Feb. (4740505.940000) PPPoE is down after 1094 minutes uptime [Waiting for Underlying Connection (WAN Ethernet 2 - Down)]
What is going on? Is it the router? If so I'll buy another one.
Geffers
10-02-2017 10:15 PM
@geffers totally agree
Our service was dropping out AGAIN this evening. Poor Poor Poor.
All I need from PN is an old school Openreach modem. That used to work and was great with my Apple Airport etc....
The PN Hub is a complete pile and at apart from giving me a clean multicast feed to my BTTV - is only good for a doorstop.
CS will be getting a call tomorrow. This service is not fit for purpose.
11-02-2017 9:26 AM
Hi DS thank you for responding.
Yes I am using the Plusnet One Hub, installed a new one on Tuesday.
It appears that I am getting the message that you posted:
What do I need to do?
Thanks.
11-02-2017 1:30 PM - edited 11-02-2017 1:32 PM
@Steviet & @mwhenham, I've made a config change to your routers that should have helped. Let me know if you're still experiencing difficulties.
Again this evening;
When is what going to be rectified? If you're talking about the upload issues, then I hope to have something more definitive to share next week, but from what I can tell you're not affected by this problem any more. A fix has already been applied to the device in question and all the above logs show is a loss of sync after almost a day of uninterrupted service
In fact, if we're talking about the connection you messaged me about, then the line has only dropped three times in the last week:
Session Started | Session Ended | Session Duration 01:23 11/Feb/2017 N/A 11:46:11 (on going) 17:30 10/Feb/2017 01:22 11/Feb/2017 7:52:26 23:14 09/Feb/2017 17:29 10/Feb/2017 18:15:7 21:33 04/Feb/2017 23:13 09/Feb/2017 5 Days, 1:40:18
If you want somebody to investigate that, then I'd suggest opening a fault ticket. Whatever the cause though, it's not related to the problem being discussed in this thread.
Again, whatever your problem, I don't think it's relevant to this upload issue. Your PPP connection has dropped once in a little over three weeks:
Session Started | Session Ended | Session Duration 22:05 10/Feb/2017 N/A 15:6:9 (on going) 13:54 19/Jan/2017 22:03 10/Feb/2017 22 Days, 8:8:52
What happened to it? Openreach have all but retired their modems from service so we'll not be able to send you another. Perhaps have a look on eBay?
