PlayStation 4 pro problems....
FIXED- Subscribe to RSS Feed
- PlayStation 4 pro problems....
Re: PlayStation 4 pro problems....
19-02-2019 2:54 PM
I can see that a new router has been ordered and that should be with you by the end of this week.
Is it a particular game that you're experiencing problems with, or every online game? Any worse than others?
The ports you've noted as forwarding which ones are they?
on 19-02-2019 3:05 PM - last edited on 20-02-2019 5:58 AM by Mav
Same problem with all online games, I can't remember all of them. But I got them from a port forwarding website that was given to me by your help desk.
Fifa 19 and call of duty Black ops 4 are the only games I play online.
Moderator's note by Mike (Mav): Post released from Spam Filter.
19-02-2019 3:14 PM
19-02-2019 4:12 PM
Hi @Malikk,
Thanks for that. I noticed you mentioned you had NAT issues previously. To my knowledge NAT Type 2 on a PS3/4 is the ideal NAT type. It's down as moderate, but by default it should mean that all relevant PS ports are open. The only thing I can see that's concerning on those pictures is the fluctuation (specifically the upload speed - the downstream looks fine). You're going to get some fluctuation, and especially running tests one after the other, but that seems rather harsh.
Would it be possible to factory reset the router back to defaults initially, and then retest plugged into one of the other ethernet ports in the back of it.
Ideally if you could run a separate hardwired test from a laptop or PC from speedtest.btwholesale.com (you won't be able to do this on your PS4 browser FYI).
19-02-2019 7:40 PM
20-02-2019 9:16 AM
20-02-2019 5:02 PM
BT Wholesale Broadband Performance Test
Broadband Speed Test Results
Test 1
Download Speed (Mbps): 31.76
Upload Speed (Mbps) : 5.97
Ping Latency (ms): 49
Test 2
Download Speed (Mbps): 30.56
Upload Speed (Mbps) : 4.27
Ping Latency (ms): 17
Test 3
Download Speed (Mbps): 34.40
Upload Speed (Mbps) : 7.02
Ping Latency (ms): 23
Test 4
Download Speed (Mbps): 33.28
Upload Speed (Mbps) : 3.04
Ping Latency (ms): 19
Test 5
Download Speed (Mbps): 33.04
Upload Speed (Mbps) : 3.36
Ping Latency (ms): 27
Test 6
Download Speed (Mbps): 33.60
Upload Speed (Mbps) : 7.29
Ping Latency (ms): 21
Test 7
Download Speed (Mbps): 31.04
Upload Speed (Mbps) : 6.86
Ping Latency (ms): 226
20-02-2019 7:53 PM
Hi @Malikk,
Thank you for sending those results over. As you've mentioned, the throughput speed looks about right but the ping is fluctuating quite a bit. I'm sorry for any inconvenience that this is causing you.
Please let us know if this issue persists once you have the new router.
20-02-2019 7:57 PM
The above tests are from the new router, this is exactly my problem. The ping and upload is very erratic, coursing huge problems with online gaming.
21-02-2019 10:49 AM
Hi @Malikk,
Thanks for confirming.
At this stage, I'd have to confirm that we've pretty much covered everything we can do in terms of your connection. If the results you've provided have been generated via a wired connection we'd need to raise this to our suppliers to investigate further as both your download and upload speeds are below the minimum we'd expect for your line.
If this is the case, please raise a fault here so that we can ask them to investigate this further for you and then let us know you've done so.
If those test results are over wifi, please re-run over a wired connection and let us know the results.
Best wishes
Dave
21-02-2019 6:29 PM
The tests i carried out were over a wired connection, and with the new router.
i have a raised a fault with the link you have have provided.
Thank you for all your help. i hope this gets sorted ASAP.
22-02-2019 9:48 AM
Thanks, I've just picked that up and have added an update to the account for you: https://www.plus.net/wizard/?p=view_question&id=187712792 - Adam
27-02-2019 2:49 PM
I played fifa last night and it was OK, not that much latency. It's a lot better. Was something done to fix the problem?
27-02-2019 3:35 PM
03-03-2019 1:24 PM
