Normal response from Plusnet?
- Normal response from Plusnet?
Re: Normal response from Plusnet?
04-04-2015 9:52 AM
If you can let us know your availability from Tuesday onwards we'll get one booked as soon as possible.
The timeslots are 8am while 1pm and 1pm while 6pm.
04-04-2015 10:00 AM
07-04-2015 9:25 AM
07-04-2015 9:36 AM
07-04-2015 9:39 AM
08-04-2015 10:04 AM
08-04-2015 11:21 AM
Your on the 80/20 service and your current sync speed is 31mbps so even if you were it wouldn't change the fact that the sync is still poor.
Leave it with me and I'll see what I can do.
08-04-2015 11:37 AM
08-04-2015 12:36 PM
09-04-2015 6:04 PM
Not to pester (actually it is to pester, but I can't think of another nice way to do it :)), but have you had any update from your supplier?
10-04-2015 9:16 AM
10-04-2015 11:32 AM
I've just looked at my ticket to see you've run tests again and are saying that another engineer visit is required. I'm guessing Plusnet and BT don't talk to each other. I'm sure my update above isn't exactly what the engineer said, however he did say that there was something that was set at the wrong speed and that it's not something he could fix. He also said it should be resolved within 48 hours, which we're now past. I don't understand why Plusnet feel another engineer visit is needed if the engineer has said there's nothing wrong with the line.
10-04-2015 1:02 PM
I don't think what the engineer said is correct as you've been provided on the 80/20 service.
There's nothing set on your line restricting your speeds so I do think another engineer visit is the best way to proceed.
10-04-2015 1:32 PM
I'm getting a little annoyed with this now. It's been nearly three weeks since I raised this fault. You're telling me one thing, and BT are telling me something else. If the Openreach engineer says the port I'm connected to has been capped at 40Mb, I can't see how another visit by another engineer is going to fix as the port in question is surely either at the cabinet or the exchange.
I'm also back at work next week and I can't guarantee anyone's going to be at home unless they can specify an exact time and not just 8-1 or 1-6.
10-04-2015 1:44 PM
I don't know why the engineer claimed the port at 40 either as the profile applied to your line clearly shows it isn't.
Your current profile is this "0.128M-80M Downstream, Error Protection Off - 0.128M-20M Upstream, Interleaving On" which means the modem is allowed to sync anywhere between 0.1mbps and 80mbps on the downstream and between 0.1mbps and 20mbps on the upstream.
If the line isn't achieving this then it could be down to a fault, crosstalk or the estimate being incorrect. For what its worth I can get you a engineer out tomorrow?
