No broadband connection since switch from sky
- Re: No broadband connection since switch from sky
22-07-2020 4:57 PM
22-07-2020 6:17 PM
Welcome to the forums, @raysauce . Have you had notification from Plusnet that you are good to go? This sounds as though the automated systems have not finished configuring your connection, which can take up to midnight of your 'go-live' date.
22-07-2020 6:29 PM
22-07-2020 6:36 PM
Ray - I assume you have a PN Hub 0 as you are posting on the ADSL board? Unfortunately, I have no experience of that modem/router, so to help me help you, is there any way you can post a picture of the hub login page?
22-07-2020 6:53 PM
22-07-2020 6:58 PM
Okay, as I have no experience of the hub1 either, I'm going to be struggling a bit. What lights are on the router, and what colour/what are they doing?
Are you on an ADSL or FTTC connection, although it doesn't really matter at this point in time?
22-07-2020 7:13 PM
22-07-2020 7:17 PM
22-07-2020 7:30 PM
Now I'm really confused. You say you have got Google to connect, but can get no further - I'm wondering if your devices have retained the Sky connection details? Just one suggestion for now - completely power down one device - preferably a desktop/laptop and then restart it and see if it can pick up the Plusnet connection credentials.
If that fails, I'm afraid you may have to wait until I can ask a more experienced member if they have any ideas, but unfortunately, all the people I would normally ask appear to be offline.
FYI - You should really have posted on the 'Fibre' board, but don't worry.
22-07-2020 7:34 PM
22-07-2020 7:39 PM
No problem - that's what we're here for, and don't worry, we'll get you sorted. I'm totally self-taught on this, and don't know everything, but there are more experienced members who will help when they spot this.
22-07-2020 7:52 PM
Moderators Note
This topic has been moved from ADSL Broadband to Fibre
22-07-2020 8:10 PM - edited 22-07-2020 8:15 PM
Two possibilities
1) the Hub one hasnt been associated correctly with your account and so the auto configuration isn't working. If you login to the router, does the broadband username show as setup@plusdsl.net ?
If so , then click the disconnect, go to settings>broadband and change the username to youraccountname@plusdsl.net and the password to your password, then click connect. If the led goes blue then you should be good to go, if not then 2) below probably applies
2) your account hasn't been fully activated yet, in which case we need a plusnet staffer to rectify
22-07-2020 8:13 PM
Thanks, @MisterW .
22-07-2020 8:16 PM - edited 22-07-2020 8:19 PM
@jab1 no problem John, let's hope it's number 1.
I dont normally use the Hub one either, but I happen to have one connected to my network as a switch and so was able to log in and check the menus
