New fiberconnection
- New fiberconnection
New fiberconnection
26-06-2017 6:25 PM
Hello
When i was ordering unlimited fiber from Plusnet i was guaranteed line speed 21-25 Mbps, my fiber was connected today but downstream on my router shows only 15Mbps, i had 17 mbps on talktalk standard broadband. Tried to reset router, would it change in next 10 days?
Re: New fiberconnection
26-06-2017 6:36 PM
quick check - what upstream does the router show as it is possible that you aren't actually on fibre
26-06-2017 6:43 PM
I added picture for speeds
26-06-2017 6:55 PM
so you are on fibre and it isn't good
what does this say for Downstream Handback Threshold http://www.dslchecker.bt.com/
on 26-06-2017 6:59 PM - last edited on 26-06-2017 7:25 PM by Mav
Doesn't showing much. don`t understand anything here
Moderator's note by Mike (Mav): Personal information removed from a public forum.
27-06-2017 9:45 AM
I can answer that - the BT database still thinks that you are on TalkTalk so doesn't give the proper answer
27-06-2017 1:49 PM
Checking the estimates for your line now shows:
Featured Products |
Downstream Line Rate(Mbps) |
Upstream Line Rate(Mbps) |
Downstream Handback Threshold(Mbps) |
WBC FTTC Availability Date |
WBC SOGEA Availability Date |
WBC FTTC 18x2 Provide Availability |
WBC FTTC 18x2 Sim Availability |
Left in Jumper |
High | Low | High | Low | |||||||
VDSL Range A (Clean) | 27.3 | 20.3 | 3.4 | 1.6 | 18.9 | Available | -- | -- | -- | -- |
And your router is currently connected at:
Test Outcome | Pass | ||||
Test Outcome Code | GTC_FTTC_SERVICE_0003 | ||||
Description | No problem found, OAM test is not currently supported on this line. | ||||
Main Fault Location | OK | ||||
Sync Status | In Sync | ||||
Downstream Speed | 15.3 Mbps | ||||
Upstream Speed | 1.9 Mbps | ||||
Appointment Required | N | ||||
Fault Report Advised | N | ||||
NTE Power Status | PowerOn | ||||
Voice Line Test Result | Pass | ||||
Bridge Tap | Not Detected | ||||
Repetitive Electrical Impulse Noise | Not Detected | ||||
Estimated Line Length In Metres | 1485.2 | ||||
Upstream Rate Assessment | Good | ||||
Downstream Rate Assessment | Reasonable | ||||
Interference Pattern | Not Detected | ||||
Service Impact | No Impact Observed | ||||
Home Wiring Problem | Not Detected | ||||
Downstream Policing Discard Rate | 0.0 | ||||
Customer Traffic Level | Upstream and Downstream Traffic Detected | ||||
Technology | VDSL | ||||
Profile Name | 0.128M-40M Downstream, Error Protection Off - 0.128M-2M Upstream, Error Protection Off | ||||
Time Stamp | 2017-06-26T12:15:00 |
So that's below the estimates for your line.
I'd advise getting this reported to us as a fault at https://faults.plus.net
27-06-2017 1:53 PM
Ok i will do it, thank you very much,
28-06-2017 2:06 PM
Fault founded. Don`t understand how but line cable supplied with plus.net router was faulty. changed cable and speed increased. Not cosmic but already better.
Thanks for trying to help.
