New connection, light was blue now orange
reynlord
Hey guys. Problem is pretty much what the title says. Connection was blue and said connected but no devices could connect. I put my actual username in and now just an orange light.
The engineer said it would only be 10 minutes from installation, been a few hours now. I tried changing my password on this site but no luck.
Any help appreciated! Maybe it's not been activated properly?
5 REPLIES 5
MatthewWheeler
Fixes: 480
Re: New connection, light was blue now orange
Hi there
I've just activated your account so you should be able to get online
 Matthew Wheeler
Mustrum
Fixes: 77
Changing your password on this site won't make a difference, its the password in the member centre you would need to change.
That said, it sounds like your account has not yet been set up - they normally say it can be any time up to midnight - though is usually sooner.
Ah, beaten to it - should be working now if you get the right password.
reynlord
amazing, i got the connection and the notification for this at the same time. great service, thank you!
reynlord
one last thing, if the speedtest is saying 21mbps, will that get close to my guaranteed speed of 67 over time?
MatthewWheeler
Fixes: 480
From what we can see your line is testing perfectly as shown below
Test Outcome Pass
Main Fault Location OK
Sync Status In Sync
Downstream Speed 80.0 Mbps
Upstream Speed 20.0 Mbps
Appointment Required N
Fault Report Advised N
NTE Power Status PowerOn
Voice Line Test Result Pass
Bridge Tap Not Detected
Technology VDSL
Current and Last 15 Minute Bin Performance
Parameters Last Traffic Count(Upto 15 mins) Current Traffic Count(Upto 15 mins)
Start Time Stamp 2018-06-07T17:20:32Z 2018-06-07T17:35:32Z
Ingress Code Violation 0 0
Egress Code Violation 0 0
Errored Seconds 0 0
Severely Errored Seconds 0 0
Unavailable Seconds 0 0
Are you testing over a wired or wireless connection? If wireless we'd recommend trying a wired connection
 Matthew Wheeler
