Netgear Orbi mesh router
- Re: Netgear Orbi mesh router
01-07-2020 8:05 PM
I’m a new Plusnet customer Fibre Extra customer. I think I need some tech help. My router hasn’t arrived so I can’t get access to my service. However I recently bought a Netgear Orbi mesh router. I’ve been told that I can’t use this on its own as I need a modem. I have also been told the router that’s due to arrive can’t fulfil the function of just a modem. Can anybody let me know whether I can use the Orbi on it’s own? or with the Plusnet router? or do I need to buy a modem? If so any recommendations on what I need?
Message 1 of 3
(1,642 Views)
2 REPLIES 2
01-07-2020 8:36 PM
You cant use the Orbi on it's own. You can use it with the Hub one though. You set the Orbi into access point mode and then connect to a lan port on the hub one ( probably with wifi disabled on the hub one ).
Alternatively you could get a separate modem such as a used BT modem ( hg612) and use the Orbi in full router mode.
Message 2 of 3
(1,635 Views)
01-07-2020 8:58 PM
Thanks for the prompt reply.
Message 3 of 3
(1,626 Views)
