Misbehaving line - GEA line test request
FIXED- Subscribe to RSS Feed
- Misbehaving line - GEA line test request
04-04-2017 9:47 PM
For a long while now I've had an intermittent HR fault on the E side of my line which results in an occasional noisy line but didn't affect FTTC. Normally I could sync for 100's of days continuously without an issue. At the start of March by SNR margin was even dropped to 4db and it has been fine for a few weeks.
On Saturday the voice service went completely dead for 10 mins and then come back - the FTTC service resynced and came back with a 5db downstream margin. I assume as a DLM response to the outage.
Since Saturday though I've had a couple more resyncs and now G.INP has been applied on the upstream which is worrying. Weirdly I can't hear any audible noise any more but from looking at the stats below something is definitely going on.
Please can you guys take a look at my line as I can't figure out what is likely to be going wrong here.
xdslcmd info --stats
xdslcmd: ADSL driver and PHY status
Status: Showtime
Retrain Reason: 1
Last initialization procedure status: 0
Max: Upstream rate = 29014 Kbps, Downstream rate = 68864 Kbps
Bearer: 0, Upstream rate = 20000 Kbps, Downstream rate = 69346 Kbps
Bearer: 1, Upstream rate = 0 Kbps, Downstream rate = 0 Kbps
Link Power State: L0
Mode: VDSL2 Annex B
VDSL2 Profile: Profile 17a
TPS-TC: PTM Mode(0x0)
Trellis: U:ON /D:ON
Line Status: No Defect
Training Status: Showtime
Down Up
SNR (dB): 5.1 11.7
Attn(dB): 15.1 0.0
Pwr(dBm): 12.6 6.8
Total time = 1 days 14 hours 37 min 22 sec
FEC: 5122301 137814
CRC: 1662 19272
ES: 38 17731
SES: 31 0
UAS: 241 211
LOS: 3 0
LOF: 25 0
LOM: 0 0
Latest 15 minutes time = 7 min 22 sec
FEC: 33 7
CRC: 0 0
ES: 0 0
SES: 0 0
UAS: 0 0
LOS: 0 0
LOF: 0 0
LOM: 0 0
Previous 15 minutes time = 15 min 0 sec
FEC: 59 19
CRC: 0 0
ES: 0 0
SES: 0 0
UAS: 0 0
LOS: 0 0
LOF: 0 0
LOM: 0 0
Latest 1 day time = 14 hours 37 min 22 sec
FEC: 4466 1032
CRC: 0 0
ES: 0 0
SES: 0 0
UAS: 0 0
LOS: 0 0
LOF: 0 0
LOM: 0 0
Previous 1 day time = 24 hours 0 sec
FEC: 7358 764
CRC: 555 255
ES: 10 248
SES: 10 0
UAS: 36 26
LOS: 1 0
LOF: 9 0
LOM: 0 0
Since Link time = 14 hours 40 min 41 sec
FEC: 4482 1035
CRC: 0 0
ES: 0 0
SES: 0 0
UAS: 0 0
LOS: 0 0
LOF: 0 0
LOM: 0 0
Fixed! Go to the fix.
Re: Misbehaving line - GEA line test request
05-04-2017 3:48 AM
Moderator's note by Mike (Mav)
A duplicate post has been released from the Spam Filter and then removed.
Forum Moderator and Customer
05-04-2017 4:12 PM
Just for info it's resynced again this morning with thousands of FEC's on the upstream - there must be a fault on this line surely ?
05-04-2017 4:26 PM
Considering that the vast majority of the VDSL2 upstream frequencies are well away from the voice range, having G.INP on the upstream shouldn't really be any different to having G.INP on the downstream? As in, it doesn't necessarily imply that your line must have some terrible fault. Considering the upstream SNRM is fairly high due to the line achieving the maximum rate with plenty to spare, you'd perhaps expect the error rate to be lower, which I'm guessing it is now that both up and down have G.INP.
Thousands of FECs is a negligible number.
05-04-2017 8:23 PM
Thanks. Just checked again and it appears that the resync was to reduce the downstream SNR margin back to 4db.
I think you're right. It looks like DLM is trying stuff out on my line to decide what is best. The reason I suspected it was a fault is previously I've had 150+ days of continuous sync. Like I say maybe I'm just going through a period where DLM is doing it's stuff.
07-04-2017 2:55 PM
Test Outcome | Pass | ||||
Test Outcome Code | GTC_FTTC_SERVICE_0001 | ||||
Description | GEA service test completed and no fault found but unable to check for customer equipment connected to modem. | ||||
Main Fault Location | OK | ||||
Sync Status | In Sync | ||||
Downstream Speed | 72.6 Mbps | ||||
Upstream Speed | 20.0 Mbps | ||||
Appointment Required | N | ||||
Fault Report Advised | N | ||||
NTE Power Status | PowerOn | ||||
Voice Line Test Result | Pass | ||||
Bridge Tap | Not Detected | ||||
Radio Frequency Ingress | Not Detected | ||||
Repetitive Electrical Impulse Noise | Not Detected | ||||
Cross Talk | Not Detected | ||||
Estimated Line Length In Metres | 405.9 | ||||
Upstream Rate Assessment | Very Good | ||||
Downstream Rate Assessment | Very Good | ||||
Interference Pattern | Regular Interference Observed Daily | ||||
Service Impact | No Impact Observed | ||||
Interference Duration Longest Occurrence | ; 00:00 to 23:45 | ||||
Interference Location | Unknown | ||||
Home Wiring Problem | Not Detected | ||||
Downstream Policing Discard Rate | 0.0 | ||||
Customer Traffic Level | Upstream and Downstream Traffic Detected | ||||
Technology | VDSL | ||||
Profile Name | 0.128M-80M Downstream, Retransmission Low - 0.128M-20M Upstream, Error Protection Off | ||||
Time Stamp | 2017-03-25T15:00:00 |
