Bizarre IP Profile Issue
- Bizarre IP Profile Issue
31-03-2017 4:09 PM
Since the line has been set up my sync speed has always been higher than 40 mbps however there has been a mismatch between the IP profile reported by the BT wholesale speedtest, GEA and the modem connection speed
The GEA profil has been stuck to 0.128-40M GINP on since the beginning despite I am on fibre extra
The IP profile is set to the connection speed I got when i changed over (40670 IP Profile 39.37) no GINP fastpath
Currently the modem is connected at 44100 with GINP on
What is going here and why is the IP profile no aligned with the sync speed?
I have logged a ticket on the 28th but no hope of a response yet...
Re: Bizarre IP Profile Issue
07-04-2017 11:43 AM
Have completed a quick GEA test and this does now show the correct profile :
GEA Test Detail | |||
Circuit ID | NA | Service ID | BBEU25198206 |
Test Outcome | Pass | ||||
Test Outcome Code | GTC_FTTC_SERVICE_0001 | ||||
Description | GEA service test completed and no fault found but unable to check for customer equipment connected to modem. | ||||
Main Fault Location | OK | ||||
Sync Status | In Sync | ||||
Downstream Speed | 44.1 Mbps | ||||
Upstream Speed | 8.2 Mbps | ||||
Appointment Required | N | ||||
Fault Report Advised | N | ||||
NTE Power Status | PowerOn | ||||
Voice Line Test Result | Pass | ||||
Bridge Tap | Not Detected | ||||
Repetitive Electrical Impulse Noise | Not Detected | ||||
Estimated Line Length In Metres | 692.5 | ||||
Upstream Rate Assessment | Reasonable | ||||
Downstream Rate Assessment | Reasonable | ||||
Interference Pattern | Not Detected | ||||
Service Impact | No Impact Observed | ||||
Home Wiring Problem | Not Detected | ||||
Downstream Policing Discard Rate | 0.0 | ||||
Customer Traffic Level | Upstream and Downstream Traffic Detected | ||||
Technology | VDSL | ||||
Profile Name | 0.128M-80M Downstream, Error Protection Off - 0.128M-20M Upstream, Error Protection Off | ||||
Time Stamp | 2017-03-25T11:45:00 |
Parameters | MIN | MAX | AVG |
Down Stream Line Rate | 40.6 Mbps | 44.1 Mbps | 42.8 Mbps |
Up Stream Line Rate | 8.2 Mbps | 8.5 Mbps | 8.3 Mbps |
Up Time | 868.0 Sec | 900.0 Sec | 899.9 Sec |
Retrains | 0.0 | 1.0 | 0.0 |
Current and Last 15 Minute Bin Performance | ||
Parameters | Last Traffic Count(Upto 15 mins) | Current Traffic Count(Upto 15 mins) |
Start Time Stamp | 2017-04-07T10:23:30Z | 2017-04-07T10:38:30Z |
Ingress Code Violation | 0 | 0 |
Egress Code Violation | 0 | 0 |
Errored Seconds | 0 | 0 |
Severely Errored Seconds | 0 | 0 |
Not sure why showed the 40/10 profile previously, as was obviously higher than this as sync speed was up at 44.1Mbps. Possibly just a display issue on our suppliers systems.
Cheers
07-04-2017 12:22 PM
Something is going on with this system
07-04-2017 12:27 PM
07-04-2017 6:26 PM
08-04-2017 6:29 AM
methinks PN need to do a up to date test ,, But why show one from 2 weeks ago ?
