Low speeds still, When the phone is fixed?
- Re: Low speeds still, When the phone is fixed?
29-01-2016 5:41 PM
This is getting a bit of a joke now.
Twice I've had a BT engineer out and they said there's nothing wrong with my phone line.
Why did Plusnet say my speeds should be between 60-80, when I'm getting 33?
Both time the BT engineer they fixed the problem.
I am wasting £5 a month for a service that you say you can not provide me, when in fact you said I can.
Is there a problem with my line still or have I been ripped off?
29-01-2016 5:58 PM
If ticket is closed ask same question on "Chat"
29-01-2016 6:08 PM
29-01-2016 9:38 PM
Quote from: cedlor Ok my suggestion would be if you have a ticket open ask straight if you have been provisioned at 40/2 instaed of 80/?
The person who I spoke to on live chat said: "the sync speeds show around the 32.4 mark but the estimation, provisioned speeds should be a lot higher"
The ticket I made last time is still open, but the last engineer that came to my house said I needed a boost engineer if the problem is still there.
29-01-2016 11:09 PM
BUT check your contract first that you are meant to be on 80
29-01-2016 11:49 PM
I mention as I had an issue and BT only tested to junction box outside front door of my house, BT said no issue found. The problem still persisted and I subsequently discovered myself it was the VDSL master socket the modem was connected to.
30-01-2016 8:45 AM
Quote from: cedlor Well go back on your ticket and tell plusnet that is what the engineer said if it does not appear on your ticket and ask them to check that you have not been set up on 40 Mbps.
It does say that the last engineer said I needed a boost engineer. Also it says I should be on fibre extra.
30-01-2016 8:47 AM
Quote from: JasonMassey Did BT test your line only to your junction box on your house, or did they test to the socket the modem is connected from.
They did both, He tested the line at my house, saying it passed the line test, but there was errors in the fibre part. Then he went to the green box and reset my line. The speed had improved from 20 to 33, but with the est speed of 62+ and the ticket said my line was stable I thought that there is something wrong somewhere.
30-01-2016 12:03 PM
fibre extra and that a boost engineer is required and ask them when that is going to happen. YOU need to keep on top of it ,sadly,I think these days
they dont have time review outstanding tickets.
EDIT
Just read another thread maybe try switching your router off for half an hour then back on in case they have changed something but the router has not updated?
30-01-2016 5:58 PM
dick:quote
