Low SNR on FTTC causing very low speeds and connection drops.
- Re: Low SNR on FTTC causing very low speeds and co...
Re: Low SNR on FTTC causing very low speeds and connection drops.
14-12-2015 10:17 AM
Downstream Speed 23.4 Mbps
Upstream Speed 3.1 Mbps
Are you running wired or wireless?
16-12-2015 10:42 PM
I am wired for the vast majority of my equipment in the house. The primary user is my Youview box for Plusnet TV.
I run my speed tests from a wired HP Microserver.
It has been getting noticeably slower despite the sync speed showing the same. Upload seems to have been unaffected.
I noticed pixelation and the quality warning message on my Plusnet TV service for the first time today when it was the only IP channel being used.
17-12-2015 9:23 PM
17-12-2015 9:30 PM
17-12-2015 9:36 PM
20-12-2015 8:15 PM
02-01-2016 1:44 PM
15-01-2016 8:17 PM
10-05-2016 12:40 AM
10-05-2016 9:15 AM
10-05-2016 9:20 AM
05-07-2016 10:57 PM
It seriously needs checking out elsewhere. It's impossible to use my TV subscription on such a slow service.
SNR is on 6db for both send and receive.
05-07-2016 10:59 PM
06-07-2016 2:03 PM
Your line has been disconnecting a fair bit over the last few days:
Featured Products |
Downstream Line Rate(Mbps) |
Upstream Line Rate(Mbps) |
Downstream Range(Mbps) |
WBC FTTC Availability Date |
WBC SOGEA Availability Date |
Left in Jumper |
High | Low | High | Low | |||||
VDSL Range A (Clean) | 24.8 | 18 | 4.2 | 2.3 | -- | Available | -- | -- |
VDSL Range B (Impacted) | 18.5 | 8.2 | 3.6 | 1 | -- | Available | -- | -- |
Current stats:
Description | Impairment in copper joint detected most likely in local network. Please continue to submit a trouble report |
Main Fault Location | LN |
Sync Status | In Sync |
Downstream Speed | 18.0 Mbps |
Upstream Speed | 2.8 Mbps |
Please open a fault report at https://faults.plus.net and we'll get this progressed.
06-07-2016 10:14 PM
