Loosing Broadband
FIXED- Subscribe to RSS Feed
- Re: Loosing Broadband
08-08-2018 3:15 PM
Three or four time a day I loose internet for a couple of minutes. Never noticed the openreach modem indicators go red, list of disconnections below for the last few days.
Any help or advice would be appreciated.
[Internet connected] IP address: 146.198.122.242, Tuesday, August 07, 2018 15:50:33
[Internet disconnected] Tuesday, August 07, 2018 15:49:51
[Internet connected] IP address: 146.198.122.242, Tuesday, August 07, 2018 04:41:13
[Internet disconnected] Tuesday, August 07, 2018 04:39:52
[Internet connected] IP address: 146.198.122.242, Tuesday, August 07, 2018 01:06:56
[Internet disconnected] Tuesday, August 07, 2018 01:05:31
[Internet connected] IP address: 146.198.122.242, Monday, August 06, 2018 22:24:49
[Internet disconnected] Monday, August 06, 2018 22:23:33
[Internet connected] IP address: 146.198.122.214, Monday, August 06, 2018 22:04:52
[Internet disconnected] Monday, August 06, 2018 22:04:08
[Internet connected] IP address: 194.75.24.36, Monday, August 06, 2018 04:13:51
[Internet disconnected] Monday, August 06, 2018 04:12:35
[Internet connected] IP address: 194.75.24.81, Sunday, August 05, 2018 21:03:44
[Internet disconnected] Sunday, August 05, 2018 21:02:45
[Internet connected] IP address: 194.75.24.35, Sunday, August 05, 2018 04:20:03
[Internet disconnected] Sunday, August 05, 2018 04:18:37
[Internet connected] IP address: 217.32.176.125, Sunday, August 05, 2018 02:07:48
[Internet disconnected] Sunday, August 05, 2018 02:06:26
[Internet connected] IP address: 51.6.9.158, Saturday, August 04, 2018 04:57:45
[Internet disconnected] Saturday, August 04, 2018 04:56:03
[Internet connected] IP address: 51.6.9.158, Saturday, August 04, 2018 04:54:23
[Internet disconnected] Saturday, August 04, 2018 04:52:52
[Internet connected] IP address: 51.6.9.158, Friday, August 03, 2018 09:08:27
[Internet disconnected] Friday, August 03, 2018 09:07:11
[Internet connected] IP address: 51.6.9.158, Thursday, August 02, 2018 22:07:24
[Internet disconnected] Thursday, August 02, 2018 22:06:24
[Internet connected] IP address: 51.6.9.158, Thursday, August 02, 2018 20:28:17
[Internet disconnected] Thursday, August 02, 2018 20:27:33
[Internet connected] IP address: 51.6.9.158, Thursday, August 02, 2018 20:06:52
[Internet disconnected] Thursday, August 02, 2018 20:06:16
[Internet connected] IP address: 194.75.24.1, Thursday, August 02, 2018 04:40:40
[Internet disconnected] Thursday, August 02, 2018 04:39:59
[Internet connected] IP address: 194.75.24.1, Thursday, August 02, 2018 00:16:10
[Internet disconnected] Thursday, August 02, 2018 00:14:53
Fixed! Go to the fix.
08-08-2018 3:53 PM - edited 08-08-2018 3:59 PM
Hello @Peakdistrict,
Sorry to hear you are experiencing an issue with your connection. I have a checked your connection and there definitely seems to be something out of place somewhere as we can see more drops in connection than we would like and a low Sync speed. Although our tests aren't picking up exactly what's causing the issue and we would need to rule out your internal wiring out by plugging the connection into your test socket which is under the faceplate of your master socket and seeing if the drops stop. This rules out internal wiring, face plates and extension sockets as being the cause. How to locate the test socket and set your connection into it can be found here:
https://community.plus.net/t5/Library/Testing-From-The-Master-Socket/ba-p/1322242
Please monitor the connection in the test socket for 24 hour and get back to us if both the speed and connection doesn't improve.
08-08-2018 5:25 PM
HI Thanks for the quick reply.
The modem is plugged directly into the top socket of the openreach Mk 3 master socket, do you want me to remove the bottom socket to disconnect all the internal wiring in the house which will leave me with no phone?
08-08-2018 5:40 PM
We would need to be in the test socket itself that's correct - if you plug in for a Microfilter you will not loose your phone connection during this time.
08-08-2018 5:57 PM
its a NTE5 vDSL socket with filters built in filters (not my socket image from net)
08-08-2018 6:25 PM
@Peakdistrict yeah that's the one - you'll need to unscrew those two screws either side of the bottom connection and then remove the faceplate - behind there you will fin the Test Socket.
08-08-2018 6:43 PM
plugged into test socket
09-08-2018 9:39 AM - edited 09-08-2018 9:41 AM
Thank you for connecting to the test socket.
I've tested your line and the test is still picking up the same issue, so we can be confident that the master socket faceplate isn't the cause of this issue. For reference, today's test result is as follows:
GEA Test Detail | |||
Circuit ID | NA | Service ID | BBEUXXXXXXXX |
Test Outcome | Fail | ||||
Test Outcome Code | GTC_FTTC_SERVICE_1114 | ||||
Description | Upstream ES and SES have exceeded threshold from real time check. Continue submitting trouble report | ||||
Main Fault Location | CI | ||||
Sync Status | In Sync | ||||
Downstream Speed | 18.9 Mbps | ||||
Upstream Speed | 1.4 Mbps | ||||
Appointment Required | N | ||||
Fault Report Advised | Y | ||||
NTE Power Status | PowerOn | ||||
Voice Line Test Result | Pass | ||||
Bridge Tap | Not Detected | ||||
Radio Frequency Ingress | Not Detected | ||||
Repetitive Electrical Impulse Noise | Not Detected | ||||
Cross Talk | Not Detected | ||||
Estimated Line Length In Metres | 1623.8 | ||||
Upstream Rate Assessment | Very Good | ||||
Downstream Rate Assessment | Very Good | ||||
Interference Pattern | Regular Interference Observed Daily | ||||
Service Impact | Retrains Observed | ||||
Interference Duration Longest Occurrence | From 03:15 to 03:30 | ||||
Interference Location | Unknown | ||||
Home Wiring Problem | Not Detected | ||||
Downstream Policing Discard Rate | 0.0 | ||||
Customer Traffic Level | Upstream and Downstream Traffic Detected | ||||
Technology | VDSL | ||||
Profile Name | 0.128M-80M Downstream 3dB, Retransmission High - 0.128M-20M Upstream, Error Protection Off | ||||
Time Stamp | 2018-07-27T09:30:00 |
Parameters | MIN | MAX | AVG |
Down Stream Line Rate | 18.9 Mbps | 20.2 Mbps | 19.6 Mbps |
Up Stream Line Rate | 1.4 Mbps | 1.6 Mbps | 1.5 Mbps |
Up Time | 627.0 Sec | 900.0 Sec | 898.7 Sec |
Retrains | 0.0 | 4.0 | 0.0 |
Current and Last 15 Minute Bin Performance | ||
Parameters | Last Traffic Count(Upto 15 mins) | Current Traffic Count(Upto 15 mins) |
Start Time Stamp | 2018-08-09T08:06:52Z | 2018-08-09T08:21:52Z |
Ingress Code Violation | 1226 | 537 |
Egress Code Violation | 5 | 66 |
Errored Seconds | 14 | 21 |
Severely Errored Seconds | 13 | 12 |
Unavailable Seconds | 0 | 0 |
Please can you run through our troubleshooting guides here and let us know how you get on? If the troubleshooting checks don't resolve the problem, please report it here and let us know when you've completed it - we'll then be able to investigate this further for you.
09-08-2018 3:12 PM
Hi
Completed troubleshooting as requested.
Line just dropped for a minute whilst i was typing this.
09-08-2018 6:16 PM
Hi @Peakdistrict,
Thanks for getting back to us and for completing the troubleshooting.
I've checked the progress of your fault and can see that our suppliers undertook some work on your line earlier today. Since that point, your line has remained stable.
Would you mind monitoring this and letting us know if the drops reoccur? We're happy to progress this to an engineer on your behalf but don't want to do that right now if the line isn't exhibiting a fault.
Kind regards,
Dave
09-08-2018 7:37 PM
Thanks for your help will keep you advised
13-08-2018 10:21 AM
Hi
Still getting a few disconnection but better than before
[Internet connected] IP address: 91.125.3.221, Monday, August 13, 2018 05:57:12
[Internet disconnected] Monday, August 13, 2018 05:56:35
[Internet connected] IP address: 91.125.3.221, Monday, August 13, 2018 05:41:04
[Internet disconnected] Monday, August 13, 2018 05:39:38
[Internet connected] IP address: 91.125.3.221, Sunday, August 12, 2018 01:28:36
[Internet disconnected] Sunday, August 12, 2018 01:27:53
[Internet connected] IP address: 91.125.3.221, Saturday, August 11, 2018 23:58:06
[Internet disconnected] Saturday, August 11, 2018 23:56:08
[Internet connected] IP address: 217.32.176.39, Friday, August 10, 2018 08:29:58
[Internet disconnected] Friday, August 10, 2018 08:29:15
[Internet connected] IP address: 217.32.176.18, Friday, August 10, 2018 06:46:17
[Internet disconnected] Friday, August 10, 2018 06:44:56
Does Plusnet do G.fast yet, its on a pole at the bottom of the garden, just going live that could improve disconnections
13-08-2018 10:34 AM
13-08-2018 1:47 PM
Personally I think the problem is your SNR is too low. The only way we have at the moment to increase this is to wait for DLM or book an engineer to take a look at the line. I'll update the ticket that's open on your account.
26-09-2018 9:13 AM
Problem sorted
Replaced the original ECI Modem with a Huawei HG612 from ebay.
Only had one drop in 16 days after which the speed has increased by 2Mbs that was 9 days ago.
Faulty modem?
21mbs down 1.5mbs up
