Loosing Broadband
Peakdistrict
Loosing Broadband
Three or four time a day I loose internet for a couple of minutes. Never noticed the openreach modem indicators go red, list of disconnections below for the last few days.
Any help or advice would be appreciated.
[Internet connected] IP address: 146.198.122.242, Tuesday, August 07, 2018 15:50:33
[Internet disconnected] Tuesday, August 07, 2018 15:49:51
[Internet connected] IP address: 146.198.122.242, Tuesday, August 07, 2018 04:41:13
[Internet disconnected] Tuesday, August 07, 2018 04:39:52
[Internet connected] IP address: 146.198.122.242, Tuesday, August 07, 2018 01:06:56
[Internet disconnected] Tuesday, August 07, 2018 01:05:31
[Internet connected] IP address: 146.198.122.242, Monday, August 06, 2018 22:24:49
[Internet disconnected] Monday, August 06, 2018 22:23:33
[Internet connected] IP address: 146.198.122.214, Monday, August 06, 2018 22:04:52
[Internet disconnected] Monday, August 06, 2018 22:04:08
[Internet connected] IP address: 194.75.24.36, Monday, August 06, 2018 04:13:51
[Internet disconnected] Monday, August 06, 2018 04:12:35
[Internet connected] IP address: 194.75.24.81, Sunday, August 05, 2018 21:03:44
[Internet disconnected] Sunday, August 05, 2018 21:02:45
[Internet connected] IP address: 194.75.24.35, Sunday, August 05, 2018 04:20:03
[Internet disconnected] Sunday, August 05, 2018 04:18:37
[Internet connected] IP address: 217.32.176.125, Sunday, August 05, 2018 02:07:48
[Internet disconnected] Sunday, August 05, 2018 02:06:26
[Internet connected] IP address: 51.6.9.158, Saturday, August 04, 2018 04:57:45
[Internet disconnected] Saturday, August 04, 2018 04:56:03
[Internet connected] IP address: 51.6.9.158, Saturday, August 04, 2018 04:54:23
[Internet disconnected] Saturday, August 04, 2018 04:52:52
[Internet connected] IP address: 51.6.9.158, Friday, August 03, 2018 09:08:27
[Internet disconnected] Friday, August 03, 2018 09:07:11
[Internet connected] IP address: 51.6.9.158, Thursday, August 02, 2018 22:07:24
[Internet disconnected] Thursday, August 02, 2018 22:06:24
[Internet connected] IP address: 51.6.9.158, Thursday, August 02, 2018 20:28:17
[Internet disconnected] Thursday, August 02, 2018 20:27:33
[Internet connected] IP address: 51.6.9.158, Thursday, August 02, 2018 20:06:52
[Internet disconnected] Thursday, August 02, 2018 20:06:16
[Internet connected] IP address: 194.75.24.1, Thursday, August 02, 2018 04:40:40
[Internet disconnected] Thursday, August 02, 2018 04:39:59
[Internet connected] IP address: 194.75.24.1, Thursday, August 02, 2018 00:16:10
[Internet disconnected] Thursday, August 02, 2018 00:14:53
21 REPLIES 21
SammyM
Fixes: 98
Re: Loosing Broadband
Hello @Peakdistrict,
Sorry to hear you are experiencing an issue with your connection. I have a checked your connection and there definitely seems to be something out of place somewhere as we can see more drops in connection than we would like and a low Sync speed. Although our tests aren't picking up exactly what's causing the issue and we would need to rule out your internal wiring out by plugging the connection into your test socket which is under the faceplate of your master socket and seeing if the drops stop. This rules out internal wiring, face plates and extension sockets as being the cause. How to locate the test socket and set your connection into it can be found here:
https://community.plus.net/t5/Library/Testing-From-The-Master-Socket/ba-p/1322242
Please monitor the connection in the test socket for 24 hour and get back to us if both the speed and connection doesn't improve.
 Sammy M - Sheffield Team
Peakdistrict
HI Thanks for the quick reply.
The modem is plugged directly into the top socket of the openreach Mk 3 master socket, do you want me to remove the bottom socket to disconnect all the internal wiring in the house which will leave me with no phone?
MasterOfReality
Fixes: 57
Hi @Peakdistrict
We would need to be in the test socket itself that's correct - if you plug in for a Microfilter you will not loose your phone connection during this time.
Peakdistrict
its a NTE5 vDSL socket with filters built in filters (not my socket image from net)
MasterOfReality
Fixes: 57
@Peakdistrict yeah that's the one - you'll need to unscrew those two screws either side of the bottom connection and then remove the faceplate - behind there you will fin the Test Socket.
Peakdistrict
plugged into test socket
EmilyD
Fixes: 117
Thank you for connecting to the test socket.
I've tested your line and the test is still picking up the same issue, so we can be confident that the master socket faceplate isn't the cause of this issue. For reference, today's test result is as follows:
GEA Test Detail
Circuit ID NA Service ID BBEUXXXXXXXX
Test Outcome Fail
Test Outcome Code GTC_FTTC_SERVICE_1114
Description Upstream ES and SES have exceeded threshold from real time check. Continue submitting trouble report
Main Fault Location CI
Sync Status In Sync
Downstream Speed 18.9 Mbps
Upstream Speed 1.4 Mbps
Appointment Required N
Fault Report Advised Y
NTE Power Status PowerOn
Voice Line Test Result Pass
Bridge Tap Not Detected
Cross Talk Not Detected
Estimated Line Length In Metres 1623.8
Upstream Rate Assessment Very Good
Interference Pattern Regular Interference Observed Daily
Service Impact Retrains Observed
Interference Duration Longest Occurrence From 03:15 to 03:30
Interference Location Unknown
Customer Traffic Level Upstream and Downstream Traffic Detected
Technology VDSL
Profile Name 0.128M-80M Downstream 3dB, Retransmission High - 0.128M-20M Upstream, Error Protection Off
Time Stamp 2018-07-27T09:30:00
Parameters MIN MAX AVG
Down Stream Line Rate 18.9 Mbps 20.2 Mbps 19.6 Mbps
Up Stream Line Rate 1.4 Mbps 1.6 Mbps 1.5 Mbps
Up Time 627.0 Sec 900.0 Sec 898.7 Sec
Retrains 0.0 4.0 0.0
Current and Last 15 Minute Bin Performance
Parameters Last Traffic Count(Upto 15 mins) Current Traffic Count(Upto 15 mins)
Start Time Stamp 2018-08-09T08:06:52Z 2018-08-09T08:21:52Z
Ingress Code Violation 1226 537
Egress Code Violation 5 66
Errored Seconds 14 21
Severely Errored Seconds 13 12
Unavailable Seconds 0 0
Please can you run through our troubleshooting guides here and let us know how you get on? If the troubleshooting checks don't resolve the problem, please report it here and let us know when you've completed it - we'll then be able to investigate this further for you.
 Emily D
Peakdistrict
Hi
Completed troubleshooting as requested.
Line just dropped for a minute whilst i was typing this.
RandallFlagg
Fixes: 75
Hi @Peakdistrict,
Thanks for getting back to us and for completing the troubleshooting.
I've checked the progress of your fault and can see that our suppliers undertook some work on your line earlier today. Since that point, your line has remained stable.
Would you mind monitoring this and letting us know if the drops reoccur? We're happy to progress this to an engineer on your behalf but don't want to do that right now if the line isn't exhibiting a fault.
Kind regards,
Dave
Peakdistrict
Thanks for your help will keep you advised
Peakdistrict
Hi
Still getting a few disconnection but better than before
[Internet connected] IP address: 91.125.3.221, Monday, August 13, 2018 05:57:12
[Internet disconnected] Monday, August 13, 2018 05:56:35
[Internet connected] IP address: 91.125.3.221, Monday, August 13, 2018 05:41:04
[Internet disconnected] Monday, August 13, 2018 05:39:38
[Internet connected] IP address: 91.125.3.221, Sunday, August 12, 2018 01:28:36
[Internet disconnected] Sunday, August 12, 2018 01:27:53
[Internet connected] IP address: 91.125.3.221, Saturday, August 11, 2018 23:58:06
[Internet disconnected] Saturday, August 11, 2018 23:56:08
[Internet connected] IP address: 217.32.176.39, Friday, August 10, 2018 08:29:58
[Internet disconnected] Friday, August 10, 2018 08:29:15
[Internet connected] IP address: 217.32.176.18, Friday, August 10, 2018 06:46:17
[Internet disconnected] Friday, August 10, 2018 06:44:56
Does Plusnet do G.fast yet, its on a pole at the bottom of the garden, just going live that could improve disconnections
Browni
Aspiring Hero
Fixes: 60
G.fast doesn't live on poles, it comes over the phone line in the same manner as FTTC, What you are seeing is probably FTTP.
plusnettony
Plusnet Staff
Plusnet Staff
Fixes: 18
Personally I think the problem is your SNR is too low. The only way we have at the moment to increase this is to wait for DLM or book an engineer to take a look at the line. I'll update the ticket that's open on your account.
 Tony T
Peakdistrict
Problem sorted
Replaced the original ECI Modem with a Huawei HG612 from ebay.
Only had one drop in 16 days after which the speed has increased by 2Mbs that was 9 days ago.
Faulty modem?
21mbs down 1.5mbs up
