Line speed query
digitalham
Line speed query
Given these line stats..
Line Stats
Downstream	Upstream
TCM(Trellis Coded Modulation)
On                   On
SNR
10.5 dB           9.6 dB
Line Attenuation
8.1 dB             0.1 dB
Path Mode
FastPath         FastPath
Interleave Depth
1                    1
Data Rate
79999 kbps   20000 kbps
MAX Rate
109048 kbps 25887 kbps
POWER
0.2 dbm        0.8 dbm
INP
1.1 symbols  0.0 symbols
CRC
4252             0
... can somebody please explain why my Plusnet recorded linespeed shows...
Estimated line speed:
Current line speed:
71 Mb
8 REPLIES 8
Plusnet Staff
Plusnet Staff
Fixes: 118
Re: Line speed query
I've tested your line @digitalham and I can see your router in sync at
Sync Status In Sync
Downstream Speed 80.0 Mbps
Upstream Speed 20.0 Mbps
Which indicates the profile on your account is set correctly.
From when I joined the Plusnet Help Team in May 2017 my main Community account is @Gandalf.
 Plusnet Staff
Fixes: 25
Surely the "Current Line Speed" of 71 is too low for a sync of 80?
@digitalham What modem/router is it? I think there might have been some weird issue in the past where someone was using an Asus router which made the IP Profile fail to update.
Edit to add: What is the IP Profile from the BT speedtester further diagnostics (don't bother rebooting anything, just run the test)?
digitalham
The BT tester also shows that the profile is incorrect but as PN seem to be incapable of even delivering the profile speed at 10am on a Saturday morning the profile isn't the deciding factor on performance
Download speedachieved during the test was - 67.39 Mbps
 For your connection, the acceptable range of speedsis 40 Mbps-71.04 Mbps .
 Additional Information:
 IP Profile for your line is - 71.04 Mbps
Upload speed achieved during the test was - 15.14Mbps
It is an Asus DSL AC68U. There is a firmware update waiting installation so I'll do that. Maybe the reboot will get the profile updated.
digitalham
Well the reboot got the profile fixed and presumably PN will get the update in due course...
Download speedachieved during the test was - 67.14 Mbps
 For your connection, the acceptable range of speedsis 40 Mbps-77.43 Mbps .
 IP Profile for your line is - 77.43 Mbps
The upstream speed is still rather disappointing though....
Upload speed achieved during the test was - 15.34Mbps
Plusnet Staff
Plusnet Staff
Fixes: 118
I've just manually matched the IP profile of your line on our systems to 77400 kbps, if you disconnect/reconnect your PPP session you should be getting a slight increase in your throughput.
 Plusnet Staff
digitalham
Thanks. I see that the profile is now correct and it has improved download a bit.
Plusnet Staff
Plusnet Staff
Fixes: 118
Awesomeness :thumbsup: glad to hear it.
 Plusnet Staff
digitalham
I'm guessing it went low after some instability or other and when DLM restored full sync it failed to alter the profile for some reason. Anyhow it is correct now and if it happens again I can just reboot to see if that sorts it out. I would have this time but was loathe to in case it made things worse rather than better.
