Line speed dropping
- Line speed dropping
Line speed dropping
30-12-2017 10:27 PM
After settling at 50 Mb/s sync my line has started to re-sync and drop in both up and down speeds
02:03:24, 08 Aug. ( 131.150000) PPPoE is up -? Down Rate=51300Kbps, Up Rate=19680Kbps; SNR
Margin Down=6.1dB, Up=6.0dB
20:34:02, 18 Sep. (3609097.150000) PPPoE is up -? Down Rate=51065Kbps, Up Rate=18943Kbps;
SNR Margin Down=5.9dB, Up=6.0dB
22:35:54, 28 Oct. ( 129.110000) PPPoE is up -? Down Rate=50490Kbps, Up Rate=19078Kbps; SNR
Margin Down=5.9dB, Up=5.9dB
03:36:46, 13 Nov. (1314155.220000) PPPoE is up -? Down Rate=49872Kbps, Up Rate=19368Kbps;
SNR Margin Down=6.0dB, Up=5.9dB
00:11:26, 21 Dec. (4584969.870000) PPPoE is up -? Down Rate=47372Kbps, Up Rate=17375Kbps;
SNR Margin Down=5.9dB, Up=5.8dB
06:40:32, 29 Dec. (5299501.670000) PPPoE is up -? Down Rate=45760Kbps, Up Rate=17529Kbps;
SNR Margin Down=5.9dB, Up=5.9dB
This is now below the line estimate:
Downstream Line Rate(Mbps) Upstream Line Rate(Mbps) Downstream Handback Threshold(Mbps)
VDSL Range A (Clean) 72.5 51.1 20 14.1 44
I've had engineer visits before but they always say the speed they measure that day is "what is to be expected for my line length" and just fit a new socket
Re: Line speed dropping
31-12-2017 1:08 AM
Moderator's note:
A duplicate post by the OP that had been caught by the Spam Filter has been released then removed.
Forum Moderator and Customer
02-01-2018 8:11 PM
Does anyone have any technical thoughts on this, before I raise a problem ticket?
