Upload speed
- Upload speed
Upload speed
02-01-2018 12:16 PM
Hello
After upload speed increase My fiber broadband only manages to reach 3,5 Mb upload. download is more or less what i expect . can anyone check it for my please
Re: Upload speed
02-01-2018 12:30 PM
What speeds does the DSL Checker expect for your line?
What speeds does it say in the HelpDesk tab on your router?
Re: Upload speed
02-01-2018 12:33 PM
DSl checker
Featured Products |
Downstream Line Rate(Mbps) |
Upstream Line Rate(Mbps) |
Downstream Handback Threshold(Mbps) |
WBC FTTC Availability Date |
WBC SOGEA Availability Date |
WBC FTTC 18x2 Provide Availability |
WBC FTTC 18x2 Sim Availability |
Left in Jumper |
High | Low | High | Low | |||||||
VDSL Range A (Clean) | 32.4 | 22.4 | 5 | 2.9 | 20 | Available | -- | -- | -- | -- |
VDSL Range B (Impacted) | 23.3 | 13.1 | 4.4 | 1.3 | 10 | Available | -- | -- | -- | -- |
Featured Products |
Downstream Range(Mbps) |
WBC FTTP Availability Date |
FTTP on Demand | 330 | 30 | -- | Available | -- | -- | -- | -- | ||
ADSL Products |
Availability Date |
Left in Jumper |
WBC ADSL 2+ | Up to 12.5 | -- | 7 to 17 | Available | -- | -- | -- | -- | ||
WBC ADSL 2+ Annex M | Up to 12.5 | Up to 1 | 7 to 17 | Available | -- | -- | -- | -- | ||
ADSL Max | Up to 8 | -- | 7 to 8 | Available | -- | -- | -- | -- | ||
WBC Fixed Rate | 2 | -- | -- | Available | -- | -- | -- | -- | ||
not shure what to check on help desk. is this line?
7. Maximum data rate: | 2693 / 30146 |
Re: Upload speed
02-01-2018 2:08 PM
As you are already near the top of the estimates there will not be much that you can do to get any better speeds.
It was the data in lines 6 and 7 I was hoping to see.
Do you have a filtered faceplate? Do you get any difference in speeds if you connect to the hidden test socket if you take the bottom half of the faceplate?
Re: Upload speed
02-01-2018 2:20 PM
I connected my router now to test socket and got even slower connection. Thanks for you answer, as i was guessing nothing could be done, because of bad line.
