Just installed although had to be ring to be activated.
- Re: Just installed although had to be ring to be a...
13-06-2018 1:08 PM - edited 13-06-2018 3:56 PM
Just went live on plusnet today seeing full sync but had to call to finally get online. Pings are higher than other line is house which is arouind 15
its 25ms on plusnet which is unusually high compared to other connection in the same house.
Can someone supply a Full GEA test here please?
Re: Just installed although had to be ring to be activated.
13-06-2018 5:10 PM
Hi there, your full GEA results are below. Are both of your ping tests being performed with a wired or wireless test? Are these tests also both being connected to the same server for testing, while being tested on the same device?
Test Outcome | Pass |
Test Outcome Code | GTC_FTTC_SERVICE_0000 |
Description | GEA service test completed and no fault found . |
Main Fault Location | OK |
Sync Status | In Sync |
Downstream Speed | 80.0 Mbps |
Upstream Speed | 20.0 Mbps |
Appointment Required | N |
Fault Report Advised | N |
NTE Power Status | PowerOn |
Voice Line Test Result | Pass |
Bridge Tap | Not Detected |
Repetitive Electrical Impulse Noise | Not Detected |
Estimated Line Length In Metres | 367.7 |
Upstream Rate Assessment | Very Good |
Downstream Rate Assessment | Very Good |
Interference Pattern | Not Detected |
Service Impact | No Impact Observed |
Home Wiring Problem | Not Detected |
Downstream Policing Discard Rate | 0.0 |
Customer Traffic Level | Upstream and Downstream Traffic Detected |
Technology | VDSL |
Profile Name | 0.128M-80M Downstream, Retransmission Low - 0.128M-20M Upstream, Error Protection Off |
Time Stamp | 2018-05-31T16:15:00 |
Looking at the results, everything seems to be where we would expect it to be speed wise. However, when taking a look at the connection uptime, I can see a few drops on there during the day. These drops could be contributing to what is causing the ping issue that you are having at the minute. Can you please confirm that you are plugged into the main socket coming in to the property and not an extension socket. You can see the drops below.
If you are plugged into the main socket, can you please try removing the cover and connecting to the test socket behind using an alternate filter, and see if this improves your connectivity for you. You can find more information on how to do this at https://community.plus.net/t5/Library/Testing-From-The-Master-Socket/ba-p/1322242.
Let us know how this goes for you.
13-06-2018 5:14 PM
Those are when moving the router. Seem's it is just an effect of Plusnet having poor routing in general. Other brand ISP is much better.
16ms to the same server whereas pnet is 23-30 has more jitter.
Can this be remedied by support is is this simply as good as it's gonna be ?
13-06-2018 5:28 PM
13-06-2018 5:49 PM
Tracing route to multiplay.co.uk [85.236.96.26]
over a maximum of 30 hops:
Uno broadband at this address.
1 <1 ms <1 ms <1 ms 192.168.1.1
2 16 ms 16 ms 16 ms 62.72.148.128
3 16 ms 17 ms 17 ms 62.72.133.89
4 16 ms 16 ms 17 ms 62.72.133.89
5 17 ms 17 ms 17 ms be51.cr05.ts1.bb.daisyplc.net [62.72.137.174]
6 16 ms 16 ms 16 ms 195.66.236.224
7 17 ms 17 ms 17 ms 185.97.60.3
8 17 ms 17 ms 16 ms ha01.multiplay.co.uk [85.236.96.26]
Trace complete.
Plus net broadband.
1 <1 ms <1 ms <1 ms bthub [192.168.1.254]
2 * * * Request timed out.
3 * * * Request timed out.
4 23 ms 23 ms 23 ms be3-3102.pcn-ir02.plus.net [195.166.143.132]
5 23 ms 23 ms 23 ms 195.99.125.140
6 23 ms 23 ms 23 ms peer8-et-7-0-1.telehouse.ukcore.bt.net [109.159.252.104]
7 * * * Request timed out.
8 23 ms 23 ms 23 ms 185.97.60.3
9 23 ms 23 ms 23 ms ha01.multiplay.co.uk [85.236.96.26]
Trace complete.
Ping was 15ms at this address last year.
Like said thats just a tracert but it was been as high as 30.
SVLAN change possible?
All connected via Gigabit ethernet.
13-06-2018 6:18 PM
That's a good shout and thanks for mentioning that.
Admittedly I didn't check the SVLAN here.
You're on a hot one where infrastructure is required and estimated for the 3rd August.
Depending on how much of the exchange is congested, we may be able to get you moved.
Unfortunately the quality assurance team in Wholesale who arrange this have gone home for the night, so I've raised ticket 176664289 to my teams workflow to contact them tomorrow for you.
13-06-2018 6:24 PM
Thanks for the info look forward to any response to improve this latency. If could be kept in the loop with details on how this will be sorted wether it be over PM telephone or just posting here.
13-06-2018 6:31 PM
14-06-2018 7:28 AM
Had a resync this morning so guessing someone has changed the SVLAN steady 15ms ping now. Perfect I just hope it's still the same in peak times. Thank you Gandalf & the team!
14-06-2018 7:59 AM
Doubt it has anything to do with SVLANs etc.
14-06-2018 8:28 AM
Yep this makes more sense. Hopefully don't see too much congestion in the evenings as the conncetion is working very sweet right now.
14-06-2018 12:00 PM
That's odd, because I haven't gotten round to contacting Wholesale yet, and our tests are still showing a capacity issue.
Due to the nature of these type of problems, you're more likely to notice it at peak times.
I've just started a chat with QA now and I'll post back shortly.
14-06-2018 12:18 PM
15-06-2018 6:51 AM
Look's like the SVLAN change has happened. Just need to wait now for the ping to drop from 25 to 15 again like it did the first time.
15-06-2018 10:31 AM
Can you confirm that this is some sort of low level error correction/interleaving that is being applied on activation of new lines? (It would account for there being 8ms added delay on ping). What DLM profile do Plusnet ask Wholesale to apply by default?
