Just installed although had to be ring to be activated.
- Just installed although had to be ring to be activ...
Re: Just installed although had to be ring to be activated.
15-06-2018 1:45 PM - edited 15-06-2018 1:46 PM
Look's like the SVLAN change has happened. Just need to wait now for the ping to drop from 25 to 15 again like it did the first time.
Our tests tally up with that too.
Can you confirm that this is some sort of low level error correction/interleaving that is being applied on activation of new lines? (It would account for there being 8ms added delay on ping).
When a new FTTC connection is provisioned, the line is put on an open DLM profile and is adjusted automatically within the first 48 hours.
Profile Name | 0.128M-80M Downstream, Retransmission Low - 0.128M-20M Upstream, Error Protection Off |
From the above it looks like you're not banded and interleaving is switched off, but retransmission is low which is another form of error correction.
What DLM profile do Plusnet ask Wholesale to apply by default?
Standard profile, which I believe is equivalent of Speed on the Openreach side.
16-06-2018 3:40 PM
Gandalf,
Could you please perform a remote DLM reset now that the SVLAN issue has been resolved as i expect this error correction is somehow staying this time causing the latency to be 25ms instead of 15ms.
Many thanks in advance
17-06-2018 11:16 AM - edited 17-06-2018 11:17 AM
Hi @digzlol7,
We're not able to perform remote DLM resets on fibre connections, I'm afraid. I've tested your line and it's all looking good from this side. For reference, today's test result is as follows:
GEA Test Detail | |||
Circuit ID | NA | Service ID | BBEUXXXXXXXXXXX |
Test Outcome | Pass | ||||
Test Outcome Code | GTC_FTTC_SERVICE_0000 | ||||
Description | GEA service test completed and no fault found . | ||||
Main Fault Location | OK | ||||
Sync Status | In Sync | ||||
Downstream Speed | 79.9 Mbps | ||||
Upstream Speed | 20.0 Mbps | ||||
Appointment Required | N | ||||
Fault Report Advised | N | ||||
NTE Power Status | PowerOn | ||||
Voice Line Test Result | Pass | ||||
Bridge Tap | Not Detected | ||||
Repetitive Electrical Impulse Noise | Not Detected | ||||
Estimated Line Length In Metres | 339.1 | ||||
Upstream Rate Assessment | Very Good | ||||
Downstream Rate Assessment | Very Good | ||||
Interference Pattern | Regular Interference Observed Daily | ||||
Service Impact | Retrains Observed | ||||
Interference Duration Longest Occurrence | From 06:00 to 06:15 | ||||
Interference Location | Unknown | ||||
Home Wiring Problem | Not Detected | ||||
Downstream Policing Discard Rate | 0.0 | ||||
Customer Traffic Level | Upstream and Downstream Traffic Detected | ||||
Technology | VDSL | ||||
Profile Name | 0.128M-80M Downstream, Retransmission Low - 0.128M-20M Upstream, Error Protection Off | ||||
Time Stamp | 2018-06-04T11:15:00 |
Parameters | MIN | MAX | AVG |
Down Stream Line Rate | 79.9 Mbps | 80.0 Mbps | 79.9 Mbps |
Up Stream Line Rate | 19.9 Mbps | 19.9 Mbps | 19.9 Mbps |
Up Time | 211.0 Sec | 900.0 Sec | 887.5 Sec |
Retrains | 0.0 | 5.0 | 0.0 |
Current and Last 15 Minute Bin Performance | ||
Parameters | Last Traffic Count(Upto 15 mins) | Current Traffic Count(Upto 15 mins) |
Start Time Stamp | 2018-06-17T09:41:01Z | 2018-06-17T09:56:01Z |
Ingress Code Violation | 0 | 0 |
Egress Code Violation | 0 | 0 |
Errored Seconds | 0 | 0 |
Severely Errored Seconds | 0 | 0 |
Unavailable Seconds | 0 | 0 |
Are you still experiencing any problems with your connection?
18-06-2018 2:13 PM
Latency is extremely poor.
Tracing route to multiplay.co.uk [85.236.96.26]
over a maximum of 30 hops:
1 <1 ms <1 ms <1 ms bthub [192.168.1.254]
2 * * * Request timed out.
3 * * 23 ms 129.hiper04.sheff.dial.plus.net.uk [195.166.143.129]
4 23 ms 23 ms 23 ms be3-3100.pcn-ir01.plus.net [195.166.143.128]
5 25 ms 25 ms 24 ms 195.99.125.136
6 23 ms 23 ms 23 ms peer8-et-0-0-4.telehouse.ukcore.bt.net [109.159.252.158]
7 * * * Request timed out.
8 25 ms 24 ms 24 ms 185.97.60.3
9 24 ms 24 ms 24 ms ha01.multiplay.co.uk [85.236.96.26]
Trace complete.
Compared to the other provider.
1 <1 ms <1 ms <1 ms 192.168.1.1
2 16 ms 16 ms 16 ms 62.72.148.128
3 17 ms 17 ms 17 ms 62.72.133.89
4 17 ms 16 ms 17 ms 62.72.133.89
5 17 ms 17 ms 17 ms be51.cr05.ts1.bb.daisyplc.net [62.72.137.174]
6 16 ms 16 ms 16 ms 195.66.236.224
7 17 ms 16 ms 16 ms 185.97.60.3
8 17 ms 17 ms 17 ms ha01.multiplay.co.uk [85.236.96.26]
You do offer Remote DLM resets as part of a trial with BT so please have the DLM reset on the line so i can have a latency to UK and EU servers which is in the range it should be.
18-06-2018 4:15 PM
Sorry to see that latency is a problem again.
A DLM reset won't help as that's for when the line has been banded by DLM and your's hasn't been, that's demonstrated by the "profile name" section of the GEA test results Emily provided you with yesterday.
I assume those results were both recorded over Ethernet?
Adam
18-06-2018 5:14 PM - edited 18-06-2018 5:14 PM
Yes. all recorded over ethernet. You are the only ISP i've ever had increased latency with on this line. After the first day the latency dropped to 15ms then you changed the SVLAN and it is now back at 25-30ms and is now staying at that. That is why I am asking for the line to be reset to that it can drop to 15 again. If this can't be done i'd rather migrate to another provider who can provide this.
18-06-2018 11:02 PM
Pinging 8.8.8.8 with 32 bytes of data:
Reply from 8.8.8.8: bytes=32 time=25ms TTL=58
Ping statistics for 8.8.8.8:
Packets: Sent = 4, Received = 4, Lost = 0 (0% loss),
Approximate round trip times in milli-seconds:
Minimum = 25ms, Maximum = 25ms, Average = 25ms
As you can see latency even to UK servers is much higher than it should be considering on the previous VLAN it was 15 now for the user who doesn't use latency intensive games and applications that would be fine but i am using servers in the and allover europe and the noridic region where having +10/15 added to the latency takes it to unacceptable levels.
My point being what harm can a DLM reset to if it proves the fix the problem? Now the fact is you are enrolled in a trial to do this remotely without an engineer visit and you have done this for customers and from the fact that the Latency was 15ms before the vlan change I would expect you would be atleast be willing to atleast try this as a option.
If you aren't willing to do this please release me from my minimum term so i can migrate to an ISP who takes customer service and latency more serious than you at PlusNet seem to do.
18-06-2018 11:24 PM
@jdigzlol7 If you look at your GEA test above :
"0.128M-80M Downstream, Retransmission Low - 0.128M-20M Upstream, Error Protection Off"
shows that a DLM reset will make no difference.
Your ping results are nothing to do with DLM - they may however depend on the gateway you are connected to.
There is a gateway tool in the member centre which might help. But rather than pinging stuff, maybe you would get more useful information using other diagnostic tools.
Can you really notice a 10msec difference in pings?
19-06-2018 12:17 AM
Sorry, the tool failed to identify your gateway; this does not mean that anything is wrong with your connection.
Other tools show the some latency so I don't see how that helps. 10ms Added to UK. EU has 20ms added . Nordic > further EU 20ms
It is most certainly noticeable.
19-06-2018 10:34 AM
@jdigzlol7 As your line isn't banded, we can't ask our suppliers to submit a DLM reset remotely as it'll simply get rejected.
With regards to the gateway checker this generally doesn't work anymore due to the way connections are now routed across our network.
These drops in your connection won't be helping your latency:
Our tests aren't completing as we'd expect so I've reported this through to our suppliers for further investigation.
19-06-2018 5:10 PM
The drops aren't due to the line they are manual. What is the reason there is added latency ? 26ms to london just isn't acceptable.
19-06-2018 5:22 PM
In that case I'd recommend against dropping the connection frequently as DLM will likely start making negative changes to your line.
I've made a change to how your service routes across our network in an attempt to try to identify the problem. Can you let us know if you are still having issues from now? Please also let us know if this resolves the issue as ideally this change can't be permanent but it should allow us to investigate further.
19-06-2018 5:27 PM
2 26 ms 26 ms 26 ms 410.xe-2-2-0.central10.psb-bng02.plus.net [84.93.253.104]
3 26 ms 27 ms 26 ms 411.be6.psb-ir01.plus.net [84.93.253.107]
4 27 ms 27 ms 26 ms core1-BE1.southbank.ukcore.bt.net [195.99.125.130]
5 28 ms 33 ms 43 ms peer8-et-7-0-2.telehouse.ukcore.bt.net [109.159.252.100]
6 * * * Request timed out.
7 27 ms 27 ms 27 ms 185.97.60.3
8 27 ms 27 ms 27 ms ha01.multiplay.co.uk [85.236.96.26]
Seems like it's been a negative impact.
19-06-2018 5:37 PM - edited 19-06-2018 5:39 PM
Looks like that rules out my theory/assumption, so I've changed your connection routing back to the way it was.
Honestly you shouldn't really be having issues with that latency. Figures aside, do you experience any real world problems whilst gaming?
It may also be worth running a trace route to pingbox1.thinkbroadband.com to rule the higher latency being caused by multiplay.co.uk
19-06-2018 5:53 PM
The reason I'm posting is because i'm having issues 27ms to london means that all outward points will be hugely higher than normal.
One example Uno Broadband line Ping time to Riot Games EUW server 28ms. Plusnet pingtime on this line 50ms visible action input lag on a fast paced game.
As requested
Tracing route to pingbox1.thinkbroadband.com [80.249.99.164]
3 * * 26 ms 129.hiper04.sheff.dial.plus.net.uk [195.166.143.129]
4 27 ms 26 ms 26 ms be3-3100.pcn-ir01.plus.net [195.166.143.128]
5 25 ms 24 ms 24 ms 195.99.125.136
6 24 ms 24 ms 25 ms peer8-et-0-0-4.telehouse.ukcore.bt.net [109.159.252.158]
8 25 ms 25 ms 27 ms po4-31.core-rs2.thdo.ncuk.net [80.249.97.85]
9 26 ms 26 ms 26 ms pingbox1.thinkbroadband.com [80.249.99.164]
It's 26ms at all stages so there is latency being added from the first hop and again over 4 years in this property you are the only ISP i've had issues such as this on.
If august wasnt so far away i would say move it back to the previous SVLAN and atleast ill have low latency but the fix time just isnt good enough and i fear that even switching back it would be stuck with this added latency and that would be even more issues.
I don't wanna spend time constantly contacting you to have this dealt with so i've placed a migration order to another ISP to go thorugh on the 5th of July if you can fix it before then i'll gladly cancel the order.
This is 2018 not 2003 these are issues which just simply shouldn't be happening.
