Intermittent connection and upstream SNRM dropping
- Re: Intermittent connection and upstream SNRM drop...
22-07-2020 3:59 PM
I have a fault that is logged and has been under investigation since early May however after 9 visits by various OpenReach engineers it seems no closer to being resolved.
This post is not to cricise the PN faults team, who now I can get hold of them are good at getting the engineers to visit. The latest BT OR Engineer, who is one of the more senior ones, seems to have run out of thing to test, swap or replace. He was able to give me his mobile number and I could call him when the fault started to occur. The faults team have escalated this with BT OR.
This post is in case anyone can provide help in identifying what the cause may be based on my description and stats from the router. Any suggestions or information that might help point BT/PN in the right direction?
My normal sync speed is about 25/4.5. I am about 900m from the cabinet, with the last 75-100m overhead.
The fault manifests itself as broadband disconnects usually mid to late afternoon as a result of a deterioration in the Upstream SNRM.
- It can happen by itself or
- Can be triggered by making or receiving a call on the landline; if not straight away then within 5 or so minutes.
- Any call usually drops the upstream SNRM by 3dB or more
This behaviour normally continues until early evening then after the next re-connect it is all back to normal speed, SNRM etc. Occasionally this gets sufficently bad that the upstream sync speed is only 500kps. Quiet line test is quiet, though when the speed is really bad there is crackling.
If I make a call that causes an upstream SNRM drop but not a reconnect then once back on hook the SNRM is back to the normal 6dB. This happens whether DECT phone or analog phone plugged straight into master socket.
I have followed all the advice/requests - a micro-splitter plugged into the master socket with just one phone and the router. Different routers - HubOne, Fritzbox, HG612 and a replacement HubOne. Different phones - Fritzbox DECT or old BT analog corded.
I have had router stats programs running (depending on the router) collecting stats and can see the upstream SNR drop away, spike etc. The download SNRM is stable through most of this.
On every single visit so far the engineers have not been able to detect any faults with their test equipment. Various BT OR Engineers have replaced the Mk3 faceplate for a Mk5; replaced the external connection box that joins the dropwire; replaced some external overhead line where probably a squirrel had chewed part way through. All to no avail.
Two attachments:
- HubOne from Monday 20th, including engineer visit with line disconnected
- HG612 today (after I swapped the router last night
xdslcmd info --stats
xdslcmd: ADSL driver and PHY status
Status: Showtime
Retrain Reason: 1
Last initialization procedure status: 0
Max: Upstream rate = 3686 Kbps, Downstream rate = 29916 Kbps
Bearer: 0, Upstream rate = 3200 Kbps, Downstream rate = 22399 Kbps
Link Power State: L0
Mode: VDSL2 Annex B
VDSL2 Profile: Profile 17a
TPS-TC: PTM Mode(0x0)
Trellis: U:ON /D:ON
Line Status: No Defect
Training Status: Showtime
Down Up
SNR (dB): 7.8 2.3
Attn(dB): 25.4 0.0
Pwr(dBm): -0.5 -0.6
VDSL2 framing
Bearer 0
MSGc: 34 424
B: 47 32
M: 1 1
T: 51 1
R: 16 16
S: 0.0681 0.3187
L: 7520 1255
D: 951 69
I: 64 50
N: 64 50
Counters
Bearer 0
OHF: 3819492 971516
OHFErr: 24 89
RS: 973913144 2686308
RSCorr: 43957 194717
RSUnCorr: 545 0
Bearer 0
HEC: 139 0
OCD: 17 0
LCD: 17 0
Total Cells: 715947787 0
Data Cells: 156068697 0
Drop Cells: 0
Bit Errors: 0 0
ES: 241 182
SES: 190 73
UAS: 509 336
AS: 16643
Bearer 0
INP: 8.00 3.50
INPRein: 0.00 0.00
delay: 16 5
PER: 4.35 17.19
OR: 73.43 200.01
AgR: 22472.21 3400.31
Bitswap: 8339/8515 185/190
Total time = 23 hours 33 min 19 sec
FEC: 1716077 3269052
CRC: 43497 537
ES: 241 182
SES: 190 73
UAS: 509 336
LOS: 13 0
LOF: 117 0
LOM: 36 0
Latest 15 minutes time = 3 min 19 sec
FEC: 1336 30669
CRC: 0 7
ES: 0 3
SES: 0 1
UAS: 0 0
LOS: 0 0
LOF: 0 0
LOM: 0 0
Previous 15 minutes time = 15 min 0 sec
FEC: 1724 47440
CRC: 0 24
ES: 0 6
SES: 0 1
UAS: 0 0
LOS: 0 0
LOF: 0 0
LOM: 0 0
Latest 1 day time = 23 hours 33 min 19 sec
CRC: 43497 537
ES: 241 182
SES: 190 73
UAS: 509 336
LOS: 13 0
LOF: 117 0
LOM: 36 0
Previous 1 day time = 0 sec
FEC: 0 0
CRC: 0 0
ES: 0 0
SES: 0 0
UAS: 0 0
LOS: 0 0
LOF: 0 0
LOM: 0 0
Since Link time = 4 hours 37 min 21 sec
FEC: 43957 194717
CRC: 24 89
ES: 1 29
SES: 0 3
UAS: 0 0
LOS: 0 0
LOF: 0 0
LOM: 0 0
Re: Intermittent connection and upstream SNRM dropping
07-08-2020 5:30 PM
The saga may have completed
After the engineer trying some more things (temporary length of overhead line; swapping onto a different pair of the underground section), all of which made some improvement to speed but not reliability; i was finally moved onto a different fibre port in the cabinet. It took the engineer 3 hours plus an overnight loss of broadband as he had difficulty in getting the service centre in India to transfer the connection.
A day and a half in the line seems stable, doesn't drop by itself or when making a phone call. I have a stable 4.5/27 connection. Hopefully I wont lose too much speed as DLM does its stuff.
The tantalising bit is that when the engineer swapped pairs after taking out the temporary overhead line, for ten minutes I synced at 6.9/45. Then he put me on another pair and I was back to 4.5/29. He tells me that DLM might get me to those speeds but currently attainable is only 5/30 at best so I don't really believe him. I have a suspicion that I might still be on a section of alu cable underground whereas the other pair was patched through a new section of copper cable they installed earlier in the year.
09-08-2020 2:53 PM
The mystery of the 50% faster sync speed for 10minutes is explained by looking more closely at the logs. The first pair that I was re-patched went to a Huawei/broadcom based cabinet with G.INP enabled. The second re-patch took me back to the normal ECI cabinet.
09-08-2020 7:25 PM
Well that blows out the water the OR mantra, we do not move subscribers to different DSLAM's!!
That aside, 900m distance (if correct) should get you a higher speed, for example I get 22Mbs @ 1500m.
If you could request a GEA test, from PN, and post it here, then we can see if there is something amiss.
Re aluminium wiring, are you sure that is the case?
09-08-2020 10:56 PM
To be fair the DSLAM move was only 10minutes and might have been a mistake!
Here are the sync stats showing the BDCM and ECI.
2020.08.03 09:03:10
xdslcmd info --vendor
Status: Showtime
Retrain Reason: 1
Max: Upstream rate = 6899 Kbps, Downstream rate = 41305 Kbps
Bearer: 0, Upstream rate = 6899 Kbps, Downstream rate = 41404 Kbps
Bearer: 1, Upstream rate = 0 Kbps, Downstream rate = 0 Kbps
ChipSet Vendor Id: BDCM:0xa49a
ChipSet VersionNumber: 0xa49a
ChipSet SerialNumber:
Other line stats show G.INP
2020.08.03 09:13:1
Status: Showtime
Retrain Reason: 1
Max: Upstream rate = 5469 Kbps, Downstream rate = 31272 Kbps
Bearer: 0, Upstream rate = 4295 Kbps, Downstream rate = 25626 Kbps
ChipSet Vendor Id: IFTN:0xb206
ChipSet VersionNumber: 0xb206
ChipSet SerialNumber: 5502456197
After the fibre port move a few days later:
2020.08.06 08:14:10
Status: Showtime
Retrain Reason: 1
Max: Upstream rate = 4856 Kbps, Downstream rate = 29408 Kbps
Bearer: 0, Upstream rate = 4780 Kbps, Downstream rate = 29535 Kbps
ChipSet SerialNumber: 5502604989
Re the alu wiring, a bit speculative on my part, but one of the BT OR engineers said they had replaced a section of underground alu earlier in the year when I asked about places where a wiring fault could be; and that was after an earlier engineer had blamed the ongoing fault on alu cable.
Obviously not the case now I looked at the actual sync stats/DSLAM vendor id.
Here is a GEA test that PN happened to add to my ticket today.
KBD
Test Outcome | Pass | ||||
Test Outcome Code | GTC_FTTC_SERVICE_0000 | ||||
Description | GEA service test completed and no fault found . | ||||
Main Fault Location | OK | ||||
Sync Status | In Sync | ||||
Downstream Speed | 28.0 Mbps | ||||
Upstream Speed | 4.8 Mbps | ||||
Appointment Required | N | ||||
Fault Report Advised | N | ||||
NTE Power Status | PowerOn | ||||
Voice Line Test Result | Pass | ||||
Radio Frequency Ingress | Not Detected | ||||
Repetitive Electrical Impulse Noise | Not Detected | ||||
Cross Talk | Not Detected | ||||
Estimated Line Length In Metres | 974.2 | ||||
Upstream Rate Assessment | Reasonable | ||||
Downstream Rate Assessment | Low | ||||
Interference Pattern | Not Detected | ||||
Service Impact | No Impact Observed | ||||
Home Wiring Problem | Not Detected | ||||
Downstream Policing Discard Rate | 0.0 | ||||
Customer Traffic Level | Upstream and Downstream traffic detected | ||||
Technology | VDSL | ||||
DP Type | External | ||||
Profile Name | 0.128M-40M Downstream, Error Protection Off - 0.128M-10M Upstream, Error Protection Off | ||||
Time Stamp | 2020-08-07T17:00:00 |
Parameters | MIN | MAX | AVG |
Down Stream Line Rate | 27.0 Mbps | 28.0 Mbps | 27.8 Mbps |
Up Stream Line Rate | 4.4 Mbps | 4.8 Mbps | 4.7 Mbps |
Up Time | 869.0 Sec | 900.0 Sec | 899.7 Sec |
Retrains | 0.0 | 1.0 | 0.0 |
Current and Last 15 Minute Bin Performance | ||
Parameters | Last Traffic Count(Upto 15 mins) | Current Traffic Count(Upto 15 mins) |
Start Time Stamp | 2020-08-09T10:00:29.204+01:00 | 2020-08-09T10:15:29.204+01:00 |
Ingress Code Violation | 0 | 0 |
Egress Code Violation | 0 | 1 |
Errored Seconds | 4 | 0 |
Severely Errored Seconds | 0 | 0 |
Unavailable Seconds | 0 | 0 |
GEA Test Detail | |||
Circuit ID | NA | Service ID |
Lots of dslstats graphs and data if that helps.
10-08-2020 7:35 AM
Looking at the GEA it shows an estimated line length of 974.2 metres, which confirms your estimate.
At that distance according ti this
https://www.increasebroadbandspeed.co.uk/2013/chart-bt-fttc-vdsl2-speed-against-distance
you should get approx 30Mbs. This is borne out by my figure of approx 21 on 1500 metre.
The attenuation figure of 25.4dB is not wildly out, mine is 32dB.
My snr is typically between 3db to 4db, on an Huawei dslam.
More of a concern are the disconnects when you make a call, which suggests an issue, possibly your face plate or the plugin filter, have you tried both? If there is still an issue then it would suggest the problem is external.
I did have an issue when I was on ADSL where as soon as the phone was lifted the speed changed, the ISP sorted it with OR.
Have you tried a line noise test
https://support.zen.co.uk/kb/Knowledgebase/Performing-a-Quiet-Line-Test
Does the issue occur every day?, is it weather dependant?
You do not appear to be suffering from interference, or crosstalk.
Disconnects etc can be hard to trace, and take a lot of patience!!
re To be fair the DSLAM move was only 10minutes and might have been a mistake!
Bit surprised OR could perform a DSLM switch in 10 minutes, this would suggst the PCAP (the other green cabinet usually within 50metres of the DSLAM) is servicing two DSLAM's, or your wires were moved over within a junction box that carried two bearer's to two different PCAP's and DSLAM'S.
How I wish OR would make a 'mistake' on my line!!!
10-08-2020 9:39 AM
Thanks for your suggestions.
The original fault was eventually fixed four days ago by moving me to another fibre port on the ECI DSLAM. I am now stable (so far) at 28-29Mbps down. The SNRM does not change when using the landline either.
BT OR went through a whole set of replacements - new master socket and faceplate; new dropwire jointing box; swapping pairs; temporary section of overhead wire. It was the switch of the fibre port that fixed it for me.
The 10minute connection to a Huawei DSLAM was part of the engineer swapping me onto a different pair in the underground section so could have been in a part that services two DSLAMs. There are two along the main road that my side road joins. One is closer to the exchange/town (mine) and one is 'down' the road and is more recent.
The main difference for that 10minutes was lower attenuation (24.0 versus 25.4) and G.INP being active. Both of which would give higher sync speeds. Wishful thinking that I could be moved onto a Huawei DSLAM permanently.
