Incorrect plusnet line speed
goldenlady46
Can plusnet please bump up their profile speed to 40Mb as I can see plusnet current line speed stuck at 8Mb
38 REPLIES 38
bobpullen
Fixes: 316
Re: Incorrect plusnet line speed
Are you sure your router is actually connecting at 40mbps? It certainly wasn't according to the last data available in the supplier systems. Navigating to the router's Helpdesk pages should tell you.
goldenlady46
Openreach Engineer just been this morning. Seem nice bloke. Repaced new master socket tested the line sync at 40/10 all ok.
https://www.plus.net/wizard/?p=view_question&id=213650507
bobpullen
Fixes: 316
Ah OK, the profile should have updated now.
goldenlady46
@bobpullen Could I have KBD GEA TEST please as the fault ticket has been closed but never ran any FTTC GEA Test from the fault team after openreach engineer been.
goldenlady46
Is any plusnet staff please ran the KBD GEA TEST and post here. DLM has retrain the line three times now since the engineer been.
@bobpullen @Gandalf
BD
Fixes: 86
Thanks for getting back to us @goldenlady46.
I can confirm when testing your connection as seen by the results below we're only currently seeing 34.8Mbps download reaching your router which looks to fall below the 38-40Mbps download estimates we have for your line.
Test Outcome
Pass
Main Fault Location OK
Sync Status In Sync
Downstream Speed 34.8 Mbps
Upstream Speed 10.0 Mbps
Appointment Required N
Fault Report Advised N
NTE Power Status PowerOn
Voice Line Test Result Pass
Radio Frequency Ingress Detected
Cross Talk Detected
Estimated Line Length In Metres 415.5
Upstream Rate Assessment Very Good
Downstream Rate Assessment Low
Technology VDSL
Current 15Min Bin Retrains 0
Last 15Min Bin Retrains 0
DP Type External
Profile Name 0.128M-40M Downstream, Retransmission Low - 0.128M-10M Upstream, Error Protection Off
Time Stamp 2021-04-23T23:30:00
Parameters MIN MAX AVG
Down Stream Line Rate 31.4 Mbps 36.5 Mbps 33.2 Mbps
Up Stream Line Rate 9.9 Mbps 9.9 Mbps 9.9 Mbps
Up Time 3.0 Sec 900.0 Sec 895.7 Sec
Retrains 0.0 1.0 0.0
Current and Last 15 Minute Bin Performance
Parameters Last Traffic Count(Upto 15 mins) Current Traffic Count(Upto 15 mins)
Start Time Stamp 2021-04-28T17:56:28Z 2021-04-28T18:11:28Z
Ingress Code Violation 0 0
Egress Code Violation 0 0
Errored Seconds 0 0
Severely Errored Seconds 0 0
Unavailable Seconds 0 0
Unlike previously however, when testing this time around we aren't picking up any underlying faults or issues that could be behind this so we'd recommend running through a few checks your side to begin ruling a number of internal factors out that could be behind this.
I'd recommend starting with basic checks here: http://goo.gl/p2tpvL
And if that doesn't help the next thing would be to rule your internal wiring out by plugging the connection into your test socket which is under the faceplate of your master socket and seeing if the speeds increase. This rules out internal wiring, face plates and extension sockets as being the cause. How to locate the test socket and set your connection into it can be found here:
https://community.plus.net/t5/Library/Testing-From-The-Master-Socket/ba-p/1322242
If you cold please drop us a message when in this set-up and remain connected this was as we can at this point re-test this side looking for any change.
Let us know how it goes.
goldenlady46
Here is screenshot
Openreach engineer installed new master socket 5C MK4 and resetted DLM
DLM Retrain 2
DLM retrain 3
It's appear DLM try to reduced target SNR 3dB and interleaved set to Retransmission High as can see the router under advanced setting.
The engineer told us there is no way to get more than 35Meg because the fibre cabinet almost full and suffer in crosstalk
goldenlady46
Line still stable but awaiting for final last DLM retrain for 3dB target SNR next step
goldenlady46
DLM has a final retrain as SNR now at 3dB
goldenlady46
@BD I just checked the last time they on 40/10 as I can see line attenuation has a very large jump from 15.5dB to 19.2dB that could result reduced to very low sync rate. Very disappointed with not getting 40/10 they are paying for as they are now struggling streaming Netflix with FTTC down to 21.4/0.5
Very low sync rateVery low sync rate
goldenlady46
@BD Could I have the latest FTTC GEA Test please as I want to see it.
Fixes: 1,600
@goldenlady46 Fresh from the printer below
GEA Test Detail
Circuit ID NA Service ID [redacted]
Test Outcome Pass
Sync Status In Sync
Downstream Speed 20.3 Mbps
Upstream Speed 0.5 Mbps
Cross Talk Detected
Interference Pattern Regular Interference Observed Daily
Interference Duration Longest Occurrence ;00:00to23:45
Interference Location Customer Premise
Interference Observed In Days 14
Technology VDSL
DP Type External
Profile Name 0.128M-40M Downstream 3dB, Retransmission High - 0.128M-10M Upstream, Error Protection Off
Time Stamp 2021-05-20T16:30:00
Down Stream Line Rate 21.3 Mbps 39.9 Mbps 38.3 Mbps
Up Stream Line Rate 0.5 Mbps 9.9 Mbps 9.1 Mbps
Up Time 2.0 Sec 900.0 Sec 893.3 Sec
Start Time Stamp 2021-06-02T14:46:49Z 2021-06-02T15:01:49Z
Errored Seconds 0 0
I'd recommend raising a fault at faults.plus.net so we can arrange an engineer visit to investigate further
goldenlady46
@Gandalf  The line was noisey at first then raised the fault. Few moment later the line return to max speed and line attenuation has returned to 15dB from 19dB. Dial 17070 for Quiet Line Test, the noisey has disappear and closed the fault now.
Speed back to normal now. Very odd but don't know what has happen.
Line has resync back to normalLine has resync back to normal
Fixes: 1,600
Aye really odd but glad to see things back to normal all the same
Let us know if there are any further issues
