Hub one VPN issues
zafaranwar12
Hub one VPN issues
Plusnetting for a few months now with no issues, in the last week or so I’m unable to wirelessly VPN (CISCO AnyConnect client) on a Hub one router. Have called the support team but hit a brick wall of anything and everything related to VPN is unsupported. Anywhere else it works fine no problem and if I hard wire at home it works fine – anyone else come across this fault/issue ?
bill888
Seasoned Pro
Fixes: 24
Re: Hub one VPN issues
Can you tell us what firmware version is installed on your Hub One?
I believe Plusnet are in the process of pushing out a new firmware update.  If you have the new version (I think it is 4.7.5.1.83.8.237.2.2), perhaps you have discovered a bug?
zafaranwar12
Hi Bill888, thanks for the quick response, will check once i get home and update. i did mention that to the technical support team that its could be related to new firmware update; but they refused to comment of SW roll outs and would not entertain any questions related to SW rollback.
should the issue be related to a bug with the new SW - what options do i have ?
My Hub 1 has been somehow been marked by PN as ceased so I don't get updates. The Cisco  AnyConnect software I use (3.1.05182)  works perfectly with the Hub 1 version - I'll check the  Hub 1 sofware version when I get home
bill888
Seasoned Pro
Fixes: 24
Finding a solution could be difficult if it is a software bug.  It could be a firewall bug.
You could check whether the issue appears on both 2.4 and 5 GHz wireless by splitting the wireless SSID network names:
https://community.plus.net/t5/My-Router/2-4ghz-and-or-5ghz-best-practice/td-p/1351950
zafaranwar12
anything is worth a try, will test once i get home - cheers.
bill888
Seasoned Pro
Fixes: 24
@bill888 - the thing here is that the Cisco VPN was working but it looks like something has changed which now stops it working for @zafaranwar12.
To confirm the version of Cisco I'm using for work works fine on both the 5Ghz, 2GHz and wired when using a Hub 1 which is at Software version 4.7.5.1.83.8.226 (Last updated 11/02/17)
Steve
zafaranwar12
Smiley just tried now and it seems to be working .. have not changed any settings. Software version on my router is 4.7.5.1.83.8.226
Don't you just love computers Grin
