Plusnet hib one, wireless clients maximum?
kand
Hi, I have a plusnet hub 1. I find that if I go over 10-12 wireless connections it either maxes out and wont allow another wireless client to connect or it locks up the home network requiring a router restart?
Does anyone else have a similar issue? Its been like this since I got it!
If this router is not up to my needs, what alternatives do I have?
many thanks
Fixes: 6
Re: Plusnet hib one, wireless clients maximum?
If you're looking for a router somewhat better, there's a good list and discussions of Fibre broadband routers here:
http://forum.kitz.co.uk/index.php/topic,14436.0.html
kand
Thanks, is my problem likely to be the "quality" of the supplied router then?
Took a quick scan of that list, but dont really know what I am looking for, suspect pay more get better!
Fixes: 6
I can't honestly say if it's the supplied router causing this wireless issue, I never used my PN Hub 1 (BT HH5A) long enough to assess the wireless performance. The lack of config options together with a very poor VDSL connection was enough for me to dump it.
The router I use at present is a ZyXel VMG8924-B10A:  it does everything I need and more, cost £40 from ebay Wink
My preference would be one with a BCM chipset, others may will disagree,  but the main thing is to read the discussions on that forum.
