How to check if I'm on Fastpath?
meekeuk
Hi Guys n Gals,
I've just recently rejoined PN after many absent years, finally binning BT Infinity and its VERY unhelpful support!
I was using the ASUS AC68U router while with BT and used it for the first few days whilst joining PN.
I have since switched to the supplied plusnet router but cannot find out if I'm interleaved or fastpath.
I was fastpath when I changed over but after a few days it went to interleaved, so that was the reason I swapped to the PN supplied router.
If I'm not on fastpath, can you please put me on it?
Thank you Smiley
5 REPLIES 5
MatthewWheeler
Fixes: 480
Re: How to check if I'm on Fastpath?
We can't change DLM on Fibre I'm afraid.
It will be a case of seeing if DLM removes it itself.
 Matthew Wheeler
meekeuk
Is there a way to check the status of the DLM?
MatthewWheeler
Fixes: 480
According to our end it isn't on at the moment.
Your profile is "0.128M-80M Downstream, Error Protection Off - 0.128M-20M Upstream, Error Protection Off"
 Matthew Wheeler
meekeuk
Ok, thank you Matthew.
I will continue using the PN router and see what happens.
Thanks again Cheesy
Andrue
* deleted * - somehow didn't see the later replies.
