Upload speed drop
lavvyheid
Upload speed drop
I used to get upload speeds on my fibre package of between 12 and 18Mbps but recently this has dropped to an average of 3Mbps.
Has this dropped on purpose or is there some sort of issue here?
1 REPLY
Plusnet Staff
Plusnet Staff
Fixes: 159
Re: Upload speed drop
Description Impairment in copper joint detected most likely in local network. Please continue to submit a trouble report
Main Fault Location LN
Sync Status In Sync
Downstream Speed 65.6 Mbps
Upstream Speed 3.7 Mbps
Looks like there's a line issue, can you report the fault to us at https://faults.plus.net
 Chris Parr
 Plusnet Staff
