How to check if I'm on Fastpath?
- Re: How to check if I'm on Fastpath?
01-07-2016 3:56 PM
Hi Guys n Gals,
I've just recently rejoined PN after many absent years, finally binning BT Infinity and its VERY unhelpful support!
I was using the ASUS AC68U router while with BT and used it for the first few days whilst joining PN.
I have since switched to the supplied plusnet router but cannot find out if I'm interleaved or fastpath.
I was fastpath when I changed over but after a few days it went to interleaved, so that was the reason I swapped to the PN supplied router.
If I'm not on fastpath, can you please put me on it?
Thank you
01-07-2016 3:58 PM
01-07-2016 3:58 PM
Is there a way to check the status of the DLM?
01-07-2016 4:07 PM
01-07-2016 4:10 PM
Ok, thank you Matthew.
I will continue using the PN router and see what happens.
Thanks again
02-07-2016 6:41 PM - edited 02-07-2016 6:42 PM
* deleted * - somehow didn't see the later replies.
