How's the Plusnet router functionality?
- Re: How's the Plusnet router functionality?
- « Previous
- Next »
08-04-2015 11:06 PM
Ah I was reading it wrong as I thought I may have. My bad
Another CPE that doesn't support G.inp properly and ends up with the DSLAM falling back to interleave, then.
Message 31 of 32
(210 Views)
09-04-2015 2:05 PM
Quote from: gkf9 Well just signed up to PN, coming from Sky 2.5 MB, hoping to get around the 33MB mark on fibre.
Install is in 2 weeks. Don't know whether to buy a decent router ready for when it's up and running?
Is the PN router that bad? Will need to do some port forwarding, but read it's not the best at this?
Honest answer. It is the WORST router i have ever come across. Port forwarding was a nightmare then the wireless was so bad. If i was in the room next to my router i would struggle to get any signal. I bought an apple airport extreme and all the problems i had disappeared.
Message 32 of 32
(210 Views)
- « Previous
- Next »
