How long does it take to achieve profile speed?
Yorkshirekev99
Hi
I've just changed to FTTC and it looks as though this has happened today. I'm aware that training occurs for 10 days, but although it appears I'm on a decent profile, I'm still getting ADSL2 speeds. I have a fairly "bespoke" but stable network, using a BT / Huawei Echolife modem (bridge mode) and a separate corporate-class firewall which terminates the PPPOE. Although I could test using the plusnet hub 1, it will be fairly disruptive so to start with I'd just like to know if I should expect to start at higher speeds and train down, or start at low speeds and train up?
The modem is reporting Upstream rate = 2000 Kbps, Downstream rate = 39998 Kbps, but I'm getting nothing like that.
Here's lots of info & stats from my testing over ethernet.
BT speed test results
7.66M down / 1.43M up / 46.25ms latency
Download speed achieved during the test was - 7.66 Mbps
For your connection, the acceptable range of speedsis 20 Mbps-38.71 Mbps .
Additional Information:
IP Profile for your line is - 38.71 Mbps
Upload speed achieved during the test was - 1.43Mbps
Upstream Rate IP profile on your line is - 2 Mbps
I'm unable to run Test 3 as I was unable to sync using the username speedtest@speedtest_domain (I also tried speedtest@plusdsl.net in case that's an unclear instruction, but same issue)
Member Centre Line Speed check
Estimated line speed:
55Mb (This may vary between 55.4Mb and 74Mb) - Checked on 2017-02-06 12:55:17
Current line speed:
8.2 Mb
# xdslcmd info --stats
xdslcmd: ADSL driver and PHY status
Status: Showtime
Retrain Reason: 0
Last initialization procedure status: 0
Max: Upstream rate = 22761 Kbps, Downstream rate = 63760 Kbps
Bearer: 0, Upstream rate = 2000 Kbps, Downstream rate = 39998 Kbps
Link Power State: L0
Mode: VDSL2 Annex B
VDSL2 Profile: Profile 17a
TPS-TC: PTM Mode(0x0)
Trellis: U:ON /D:ON
Line Status: No Defect
Training Status: Showtime
Down Up
SNR (dB): 18.4 20.5
Attn(dB): 17.9 0.0
Pwr(dBm): 12.5 5.1
VDSL2 framing
Bearer 0
MSGc: 26 330
B: 237 48
M: 1 1
T: 64 6
R: 16 16
S: 0.1893 0.7651
L: 10736 711
😧 1 1
I: 254 68
N: 254 68
Counters
Bearer 0
OHF: 4912265 928843
OHFErr: 12 7
RS: 314363922 694024
RSCorr: 90 0
RSUnCorr: 64 0
Bearer 0
HEC: 108 0
OCD: 7 0
LCD: 7 0
Total Cells: 1148624271 0
Data Cells: 7379085 0
Drop Cells: 0
Bit Errors: 0 0
ES: 12 2
SES: 0 0
UAS: 28 230181
AS: 14924
Bearer 0
INP: 0.00 0.00
INPRein: 0.00 0.00
delay: 0 0
PER: 3.04 16.13
OR: 84.20 166.64
AgR: 40082.29 2166.36
Bitswap: 10874/10874 0/0
Total time = 4 hours 9 min 12 sec
FEC: 90 0
CRC: 12 7
ES: 12 2
SES: 0 0
UAS: 28 230181
LOS: 0 0
LOF: 0 0
LOM: 0 0
Latest 15 minutes time = 9 min 12 sec
FEC: 1 0
CRC: 0 0
ES: 0 0
SES: 0 0
UAS: 0 0
LOS: 0 0
LOF: 0 0
LOM: 0 0
Previous 15 minutes time = 15 min 0 sec
FEC: 6 0
CRC: 0 0
ES: 0 0
SES: 0 0
UAS: 0 0
LOS: 0 0
LOF: 0 0
LOM: 0 0
Latest 1 day time = 4 hours 9 min 12 sec
FEC: 90 0
CRC: 12 7
ES: 12 2
SES: 0 0
UAS: 28 230181
LOS: 0 0
LOF: 0 0
LOM: 0 0
Previous 1 day time = 0 sec
FEC: 0 0
CRC: 0 0
ES: 0 0
SES: 0 0
UAS: 0 0
LOS: 0 0
LOF: 0 0
LOM: 0 0
Since Link time = 4 hours 8 min 43 sec
FEC: 90 0
CRC: 12 7
ES: 12 2
SES: 0 0
UAS: 0 230153
LOS: 0 0
LOF: 0 0
LOM: 0 0
# xdslcmd info --pbParams
Status: Showtime
Retrain Reason: 0
Max: Upstream rate = 22730 Kbps, Downstream rate = 63760 Kbps
Discovery Phase (Initial) Band Plan
US: (6,31) (882,1193) (1984,2770)
DS: (33,857) (1218,1959) (2795,4083)
Medley Phase (Final) Band Plan
DS: (41,857) (1218,1959) (2795,4083)
VDSL Port Details Upstream Downstream
Attainable Net Data Rate: 22730 kbps 63760 kbps
Actual Aggregate Tx Power: 5.1 dBm 12.6 dBm
VDSL Band Status U0 U1 U2 U3 U4 D1 D2 D3
Line Attenuation(dB): 6.6 26.4 36.9 N/A N/A 12.6 30.3 47.0
Signal Attenuation(dB): 6.4 26.4 36.8 N/A N/A 17.8 30.1 47.0
SNR Margin(dB): 29.4 20.1 20.4 N/A N/A 18.4 18.4 18.4
TX Power(dBm): -6.9 -19.3 4.8 N/A N/A 9.0 7.6 6.6
TIA
2 REPLIES 2
RealAleMadrid
Aspiring Hero
Fixes: 59
Re: How long does it take to achieve profile speed?
It's nothing to do with training which doesn't take 10 days, it syncs as fast as it can and the speed may be reduced if there are a lot of errors. However you are syncing at the maximum speeds for the 40/2 service so that's good. You need to call customer support and ask them to update your profile which is still set to ADSL speeds and needs manual intervention to sort it. I had to do this when I was upgraded to FTTC last weekend. I'm quite close to the cabinet and get 79987Mbps down / 19999Mbps up sync speeds.
Yorkshirekev99
Thanks RealAle - sorted me out again Smiley
37.32M down / 1.46M up - looking better!
