High packet loss and other DNS issues
- High packet loss and other DNS issues
Re: Packet loss
21-09-2016 9:07 PM
ok done that
Re: Packet loss
21-09-2016 9:08 PM - edited 21-09-2016 9:11 PM
Re: Packet loss
21-09-2016 9:16 PM - edited 21-09-2016 9:37 PM
I'm bored so, for fun, here is a 10 min ping plotter trace at 21:00 this evening, 1 second intervals...
Followed by one a few minutes later... Gotta love responses of over 1000ms...
Re: Packet loss
21-09-2016 9:16 PM
@Terranova667 if you read what I said
whatever you are using, it is not set up correctly to respond to pings.
you will notice I never mentioned any hardware and as for reading the manual that was a direct link to the TBB FAQ sublinked to the exact error.
Re: Packet loss
21-09-2016 9:22 PM
@Browni I read what you said and it was wrong, so not sure what point your trying to make.
Re: Packet loss
21-09-2016 9:29 PM
Cool, thanks for replies. Anybody can recommend any Plusnet alternatives?
Re: Packet loss
21-09-2016 9:51 PM
Experienced all the issues noted in this thread. Got nowhere on live chat, told twice that they had changed some settings and to rest the router, and once to change my wifi channel, all showed no results.
Just paid for static IP, everything immediately works properly again! Pointed out to PN I shouldn't have to pay for my service to resume as normal like it was prior to the change in network. Will see if they respond.
Re: Packet loss
21-09-2016 9:59 PM
Can't game, can just browse and pingplot- what an exciting life I currently lead lmao
Re: Packet loss
21-09-2016 10:05 PM
Re: Packet loss
22-09-2016 6:01 AM
I too am having a heap of packet loss and it seems the 141.hiper04.sheff.dial.plus.net.uk is the common cause.
Re: High packet loss and other DNS issues
22-09-2016 6:07 AM
The 141.hiper04.sheff.dial.plus.net.uk seems to be a common fault, it appears in several of the posts as the location of packet loss
Re: Packet loss
22-09-2016 8:07 AM
does this look bad ?
Re: Packet loss
22-09-2016 4:08 PM
Come on Plusnet staff admit that this "issue" is your implementation of a new traffic management system, i've just ran 2 tests on ping test and at 15:59 my ping was 22ms with Jitter of 1ms, 16:01 my ping is 87ms with Jitter of 60ms.
This is no coincidence, my streaming of music from Deezer,Youzeek or Spotify is now distorted and stuttering and streaming any video is almost impossible even at low quality.
Re: Packet loss
22-09-2016 6:09 PM
As some of us were given a static IP free without issue you certtainly should push for your money back. The fact that is a cure of sorts (masking the problem somehow) is reason enough to get it free.
Apart from more jitter than I would like ive had no packet loss issues.
Re: Packet loss
22-09-2016 8:14 PM
I was also suffering from packet loss, ranging anywhere from 8% to 30% over a few hundred simple pings to _very_ reliable IP addresses. I play World of Warcraft, and basically this made the game unplayable.
I contacted Plusnet support three days ago, and they offered no solution (no free static IP address), just to expect it to be fixed within a couple of days.
So I went ahead and added a static IP address addon for a fiver (I think), and restarted the router. BAZINGA. No packet loss:
Quite ridiculous.
Are we all being a bit too British, and not complaining enough about this? Does some governing body need to be contact about this utterly shameful service, and the continued silence from Plusnet?
