High packet loss and other DNS issues
- High packet loss and other DNS issues
Re: Performance Woes Hamper PlusNet Users as New Network Takes Blame
08-09-2016 8:12 PM
08-09-2016 8:17 PM
I'll keep monitoring it and see if there are any changes in packet loss, so far still showing 0%
08-09-2016 8:19 PM
@SpendLessTime wrote:
Or you have static IP which you can checked for at https://www.plus.net/my.html?action=myconnection
Oh that says I'm static IP, so got old network as well today.
08-09-2016 8:21 PM
We are aware of the issue and that is is happening normally around 6pm onward the networks team are looking into resolving the issue but we don't have an exact time currently I'm sorry about this.
And
we don't have anything currently for the networks team regarding what is the cause of yet I'm sorry that this is affecting you but we do understand the amount of people having this issue and that it needs resolving as soon as possible. I'm sure once the issue is resolving we can look into a goodwill for the inconvenience of this.
Well, there we have it ladies and gents...
My packetloss is currently 60%....
08-09-2016 8:26 PM
08-09-2016 8:31 PM
How'd you get that?
08-09-2016 8:35 PM
No you haven't - you are still on the new WBMC Dedicated network but tunnelled through to one of the old gateways.
See the post I made two days ago: https://community.plus.net/t5/Fibre-Broadband/High-packet-loss-and-other-DNS-issues/m-p/1364514#M456...
@jelv wrote:
There seems to be a common mistake being made by people regarding fixed IPs and the old/new network. People on fixed IPs can still be on the new network.
The old network uses WBMC Shared, the new network WBMC Dedicated. See http://forum.kitz.co.uk/index.php/topic,16711.0.html for a detailed explanation.
When people on fixed IPs are moved to the new network their connection is tunnelled through to one of the old bng gateways (i.e. although it is going through the initial part of the new WBMC Dedicated network all of that is hidden in the tracert).
Dave posted about this here:
@dave wrote:
That's me, I've added static IPs to a few of you to see whether that makes a difference as it changes the way your traffic routes through the network. With a static IP your traffic coming to us from you follows the same route up to a point and then goes a different way out the Internet via one of the BNGs.
If you were moved to the new network, experienced issues and then had fixed IP added, you will still be on the new network - it's just that some of your routing goes through a different path to the routing for those on dynamic IPs.
For people on fixed IPs it is not possible to tell if you are on WBMC Shared or WBMC Dedicated.
08-09-2016 8:38 PM - edited 08-09-2016 8:38 PM
I've just been given a static IP it seems. I also rebooted my router, currently 0% packetloss....
Was 60%
08-09-2016 8:43 PM
Bless you based static IP god watching over us tonight
08-09-2016 8:45 PM
haha yes.
Speed is down to 1mb/s (usually 5.8mb/s for my line) - but, atleast its useable now I guess.
08-09-2016 8:50 PM
http://usertools.plus.net/@gateway/
You are currently connected to gateway ptw-bng01.
This is located in Telehouse West.
Was told that means old Network.
08-09-2016 8:51 PM
for me Unfortuantely I didn't try that an hour ago!
08-09-2016 9:00 PM
Sorry...
I spoke too soon..
Back to 30% loss and download speeds plummiting once more
08-09-2016 9:04 PM
Still showing 0% for me and the fact you are seeing speed drops says to me you have another issue going on with your connection.
At no point have i had any speed drops, only packet loss.
08-09-2016 9:13 PM
This is the first time I've had speed loss since the issues started, not sure why.
Will give the router another reboot in a bit to see if that helps....
