G.INP
- Re: G.INP
Re: G.INP
22-03-2015 3:48 PM
If you have unlocked modem you may still get automatic firmware upgrades (as I do) or you may not. For me with the automatic upgrades: I lost the web access to the modem but kept the telnet access.
Re: G.INP
22-03-2015 4:45 PM
Re: G.INP
23-03-2015 8:55 AM
Re: G.INP
23-03-2015 9:09 AM
Quote from: Starmans 25ms to 8ms.
hopefully that's a sign of G.Inp's capability and not just a happy coincidence.
Re: G.INP
23-03-2015 9:11 AM
Re: G.INP
23-03-2015 9:34 AM
if it hasn't changed one of the CRT can do it for you, once changed you will need to drop the session in the router for the speed to take effect.
Re: G.INP
23-03-2015 5:12 PM
Quote from: chrcoluk ECI rollout has NOT yet started, it will start during Q1 in the next fiscal year.
Incorrect.
There was an ECI trial back in December. Rollout for ECI DSLAMs has just begun and is expected to be complete by the end of June. The Huawei DSLAMs were due to be completed by the end of March.
Re: G.INP
23-03-2015 5:27 PM
Re: G.INP
23-03-2015 5:46 PM
Re: G.INP
23-03-2015 5:52 PM
Re: G.INP
23-03-2015 9:41 PM
I have attached the stats montages for the last 24 hours.
The switch from non-G.INP Bearer 0 only to G.INP activated on Bearer 0 & Bearer 1 is easy to spot, as are the changes to various counts.
I'm not immediately 'feeling' any advantages from G.INP being activated, but maybe the reduced/non-existent ES, CRC, HEC counts etc. will help in time.
These seem to have been replaced by FEC/RSCorr, mainly on Bearer 0, but with a few on Bearer 1.
Also, non-Bearer specific rtx_tx & rtx_c are now playing a part.
The G.INP montage includes LEFTRS delta values, but for an overview, I have also attached the cumulative DS LEFTRS graph on its own.
I'll be keeping my eagle eye on things for the next few days in case DLM decides it likes what it now sees & removes or adjusts the sync speed capping/banding at 22.4/5 on my connection.
Re: G.INP
23-03-2015 9:57 PM
Re: G.INP
24-03-2015 4:20 AM
Quote from: AndyH
Incorrect.
incorrect.
Re: G.INP
24-03-2015 6:21 AM
Re: G.INP
24-03-2015 8:02 AM
andyh you are some unknown guy on a forum who claims to work for a company that is a BTw customer, you spend your entire working day sitting on forums answering posts, and I am to believe you over TWO openreach employees?
where is this mysterious already started ECI rollout? post codes, towns?
you dug yourself a hole with the earlier lie, now I guess its easier to carry it on then admit it.
