Frequent Internet disconnections
- Re: Frequent Internet disconnections
04-03-2022 11:27 PM
04-03-2022 11:35 PM
05-03-2022 7:50 AM
@Lukeyboygb What do you mean by 'internet drops'? What do the Hub lights do during these 'drops'?
05-03-2022 10:43 AM
05-03-2022 10:48 AM
@Lukeyboygb Very strange. The only suggestion I can make at the moment is to suggest that you post a copy of your Hubs Event log, and we can see if that gives us any clues as to what is happening.
05-03-2022 10:48 AM
05-03-2022 10:50 AM
05-03-2022 10:51 AM
OK. If you can post the logs, though, preferably from the Hub2, it may help.
05-03-2022 11:07 AM
Are you connecting via wireless? If so does the same happen if you use an Ethernet cable?
06-03-2022 3:36 PM
Hiya @Lukeyboygb,
I'm really sorry you are experiencing an issue with your connection and for the inconvenience this is causing.
I have run some tests on the connection and its not flagging up any external fault.
Please can you look at the image below and let me know the drops there match up with what you are seeing? and if any of them are where you have rebooted the router.
