Fluctuating SNR Dropping Connections
deank
Fixes: 14
Re: Fluctuating SNR Dropping Connections
Hi @Anonymous
I have booked an appointment for you. You can view the ticket here.
@deank, @RandallFlagg, @TheMightyAJ (Sorry for the mass @ guys).
OK, the first engineer arrived at 08:00 this morning and the second one has just left. He said that the SNR margin on my profile as provided by yourself was too low and is now set at 6dB and everything else is working as expected. If the truth be told I'm not convinced as the line is now syncing thus:
Large loss of capacity here!
I think this is treating the symptom and not the cause.
RandallFlagg
Fixes: 75
Hi @Anonymous
Thanks for getting in touch.
Your line is looking good - the external fault we detected previously has now disappeared.
If the engineer has reset the DLM profile (which he will have done to reset the SnR) it should be expected that your speed takes a bit of a hit until the DLM settles down again - this can take a few days.
As things stand, I'm not concerned - just wait for the line to re-sync and you'll get your speed back.
Incidentally, the line profile/DLM/SnR are all dictated by software on the line itself - we have no influence over that as the engineer seems to have incorrectly suggested.
Best wishes.
Dave
ejs
Aspiring Hero
Fixes: 25
I'm still not convinced about the validity of those stats. All the stats you've posted show the upstream SNRM as equal to the downstream SNRM, which doesn't seem likely (presumably it's showing the downstream twice). The units imply that what's shown as 6(0.1dB) is 0.6dB, but unless sometimes it shows something like 60(0.1dB), I'll assume 6(0.1dB) is really 6dB.
@ejs - I'm not (never have been) convinced either but I don't know enough about this stuff to make any real assessment. What I post is what the router show's me from the modem(s).
If you are convinced that it's not right then I'd be happy to raise the question with DrayTek support. But that then raises the question if it is broken then why hasn't someone else mentioned it to them due to the huge user base the modem has?
@RandallFlagg, @deank, @TheMightyAJ - Well so much for the engineers visit! The line is still dropping repeatedly and the speed hasn't returned to what it was before. Do you guys have any thoughts (well ones you can publish here) on what to do next?
BD
Fixes: 86
Hi @Anonymous, sorry to hear you're still having connection issues. checking over your connection it's no longer identifying a external issue however looking at the graph below we are seeing a awful lot of drops. On top of this we are only seeing 61.5Mbps download getting to your router when your estimates advise it should be 69.5-80Mbps which hints there's something out of place somewhere.
In which case, I'd advise before we go down the route of getting a engineer out to visit the property we do 1 or 2 further checks on your side given our testing is no longer detecting a external issue.
The next thing would be to rule your internal wiring out by plugging the connection into your test socket which is under the face plate of your master socket and seeing if the drops stop. ( I can see you've already tried the master socket however there are still internal components that could be behind the drops) This rules out internal wiring, face plates and extension sockets as being the cause. How to locate the test socket and set your connection into it can be found here
(If possible, I'd recommend using a alternative modem/router to rule these things out when in this set-up as they could also be the cause behind the drops.)
Given the frequency of the drops you should know within 24 hours whether the issue persists or not and this should determine our next course of action. Let us know how it goes.
@BD on checking the router this morning I see that the DL/UL has started to recover so I'll leave it for a few more days before I start to unplug things for testing. BFWIW we don't have any extensions wired up, these were disconnected a good while back by the OR engineer at my request as the phones on the main line are cordless.
brookheather
Have you tried swapping round the two modems in case one of them is developing a hardware fault?
BT FTTP 500 + pfSense + Uniquiti Unifi 6 Pro
That's a good idea @brookheather although it had already occurred to me to do this and if I need to do further testing I will adopt that approach as I don't have a spare modem and well help point the finger as to where the issue might be.
LaurenB
Fixes: 131
Hi @Anonymous, the connection is looking a lot more stable today, did you manage to get connected to the test socket?
If the speed has improved also, I'd advise to continue to monitor and if you start noticing issues again, just get back to us.
 Lauren Barry
Hi @LaurenB, no I haven't done this yet and I don't intend to do this for a few days, and only if I need to. I want to limit the disruption of the service as mush as possible to see if it's going to recover. But don't worry, you guys will be the second to know if anything goes wrong, that I can assure you. Grin
I see that my connection is still dropping and the SNR on the first line is currently at 1 so heading toward 0 and a reset. I have a new router arriving tomorrow so I'll put that in place then if I have time, but in the meantime can I have a VR graph from the 7th until the present please.
Fixes: 1,601
Sure thing Mook. Here you go:
Let us know how it goes when you setup your new router.
Thanks @Gandalf, but it's 6 days short. Wink
