Fibre speed down to ~2Mbps this evening
danieljohn
Hi guys,
my internet is very slow this evening, down to ~2Mbps instead of the usual 12/13Mbps. According to the 'status' page there are no known issues with broadband. All my devices show the same speed, is something going on?
Thanks,
Daniel
3 REPLIES 3
MatthewWheeler
Fixes: 480
Re: Fibre speed down to ~2Mbps this evening
Our tests aren't showing any cause for this.
Are you testing over a wired or wireless connection?
If wireless can you try a wired connection?
 Matthew Wheeler
danieljohn
Hi guys,
I've just been testing the speed and it seems to be up to ~12Mbps again. One test returned ~35Mbps, which I think is impossible! We tested the speed on many devices the other day, the wireless works fine and is unlikely to be so broken it was the bottleneck. I suppose it isn't ruled out....
Thanks,
Daniel
HarryB
Fixes: 256
Hi @danieljohn those tests look fine, especially for a wireless connection. The one at 35Mbps is likely just a bit of an inaccurate reading which can happen from time to time on speed testers.
 Harry Beesley
