Re: Broadband dropping and low speeds
andyglider
I'm having the same problems of broadband just dropping out of up to 15 minutes at a time and now very slow speeds. I agree that BT will probably come when it is working again so proving nothing. Anyway I've sent my speed test to Plusnet help to see what is next. Love the way they say it could cost you £65 if the fault is found to be at your end. The router is plugged directly into the main socket so how an it be at my end. This is the second router I've had and I wasn't convinced there was a problem with the first one anyway.
Moderator's note by Mike (Mav): Changed thread title after split to its own thread.
Fixes: 219
Re: Broadband connection problems
@andyglider Sorry to hear you're having issues.
Our tests aren't showing any causes but I can the speedtest result wasn't brilliant.
Just to confirm was that over a wired or wireless connection?
 Matthew Wheeler
andyglider
Hi.
It was over wired cat5 cable, but same happens over wireless. I'm getting 2 to 3mps download at the moment when I normally get around 75mbs.
Regards
Andrew
Fixes: 165
I'd advise getting this reported to us as a fault at https://faults.plus.net
 Chris Parr
 Plusnet Staff
Fixes: 232
Moderator's note:
Split to new thread and title changed.
Forum Moderator and Customer
