Fibre service activation...
stehooper
My fibre was active for around 10-15 minutes this morning and then back to nothing. What's going on?
6 REPLIES 6
stehooper
Re: Fibre service activation...
Just watched you fix it... Good form, thanks.
MatthewWheeler
Fixes: 479
I've just activated your account and I can see you're now online.
 Matthew Wheeler
stehooper
Would you be able to check the speed for me? Just done a test and it's half what was quoted, thanks again.
MatthewWheeler
Fixes: 479
Are you testing the speed over wired or wireless?
 Matthew Wheeler
stehooper
PC is wired and laptop is obviously wireless, both showing the same speeds. It's not slow, just fiber at the lower rate... 38mb.
Chris
Legend
Fixes: 169
Test Outcome Pass
Test Outcome Code GTC_FTTC_SERVICE_0001
Description GEA service test completed and no fault found but unable to check for customer equipment connected to modem.
Main Fault Location OK
Sync Status In Sync
Downstream Speed 80.0 Mbps
Upstream Speed 20.0 Mbps
The line is in sync at full 80/20 speeds and the profile looks ok from our side.
Can you run a BT Speedtest for me, ensuring you do the further diagnostics test after the first one completes. This stores the results on the supplier system and allows us to use this to report the fault.
