Fibre service activation...
- Fibre service activation...
09-11-2016 11:21 AM
My fibre was active for around 10-15 minutes this morning and then back to nothing. What's going on?
Re: Fibre service activation...
09-11-2016 11:26 AM
Just watched you fix it... Good form, thanks.
09-11-2016 11:28 AM
09-11-2016 11:28 AM
Would you be able to check the speed for me? Just done a test and it's half what was quoted, thanks again.
09-11-2016 11:34 AM
09-11-2016 11:37 AM
PC is wired and laptop is obviously wireless, both showing the same speeds. It's not slow, just fiber at the lower rate... 38mb.
10-11-2016 11:55 AM
Test Outcome | Pass |
Test Outcome Code | GTC_FTTC_SERVICE_0001 |
Description | GEA service test completed and no fault found but unable to check for customer equipment connected to modem. |
Main Fault Location | OK |
Sync Status | In Sync |
Downstream Speed | 80.0 Mbps |
Upstream Speed | 20.0 Mbps |
The line is in sync at full 80/20 speeds and the profile looks ok from our side.
Can you run a BT Speedtest for me, ensuring you do the further diagnostics test after the first one completes. This stores the results on the supplier system and allows us to use this to report the fault.
