Fibre installation cut off internal phone extension
- Fibre installation cut off internal phone extensio...
28-08-2015 4:37 PM
PlusNet very recently helped me with a difficult fibre installation and I cannot fault them the customer service. Fabulous!
But I have just discovered the OpenReach engineer who rewired our master socket has succeeded in cutting off our front room telephone socket. I DID tell him we had three points - master and two extensions, and he moved our master from under the stairs to our main room but something has happened to our front room extension in the process. Because I have Sky Multi-Room, it won't be long before Sky will be threatening me with 'sending the boys around' for having an unplugged satellite. Sadly I was unable to check at the time because the line was behind a cabinet and it didn't occur to me he would cut it off.
Naturally our dear pal Jess can't answer this question (being a Commodore 64 computer). So I'm hoping Matt or others on staff might be able to spot this conundrum and see if the situation can be put right some time
In hope and thanks,
Clive
In hope and thanks,
Clive
Message 1 of 4
(700 Views)
3 REPLIES 3
Re: Fibre installation cut off internal phone extension
28-08-2015 4:39 PM
Message 2 of 4
(522 Views)
28-08-2015 5:26 PM
Thank you! That's tremendously helpful!
Clive
Clive
Message 3 of 4
(522 Views)
28-08-2015 5:44 PM
I think now Sky boxes have internet connection they no longer need the phone
To do is to be - Neitzsche
To be is to do - Kant
do be do be do - Sinatra
Message 4 of 4
(522 Views)
