Fibre connection not performing as it used to
- Re: Fibre connection not performing as it used to
23-04-2015 11:03 AM
I had my fibre connection set up around a year ago, in March 2014. At the time I had a pretty amazing connection, single digit pings and 70mb downstream with 17/18mb upstream.
I did experience some issues which were resolved after a few engineer visits in August 2014 (http://community.plus.net/forum/index.php?topic=128962). Since then it's been far more reliable (not perfect mind you).
However, last night I was looking through my speedtest statistics and have seen that my connection has dropped from 70mb downstream from when it was first installed and pings frequently around 9/10ms to 50mb downstream and pings in excess of 25/30ms.
I don't think I'm getting the full potential from the connection, if I can squeeze some extra performance out of i without affecting the quality that would be great.
Let me know what you need from me.
Edit: I'm using a BT Home Hub 5.
Message 1 of 6
(675 Views)
5 REPLIES 5
23-04-2015 11:16 AM
You should get your 70 back its what your paying for, its really odd because my connection was 74 down 18 up untill 3 days ago and now im 62 down 18 up. Im wondering if this G.INP thingy that BT is rolling out is the reason why so many customers are noticing speed drops. Ive just read that G.INP should improve connections...
Message 2 of 6
(450 Views)
23-04-2015 11:22 AM
Quote You should get your 70 back its what your paying for,
The payment is for a service at the fastest speeds we can provide, based on the estimates. We cannot (nor can any other ISP) guarantee that the speed won't change.
Message 3 of 6
(450 Views)
23-04-2015 11:32 AM
I agree, if I hadn't connected at 70mb historically it wouldn't be so much of an issue. The downstream seems to jump all over the place with 50mb being the highest, last night was 5mb.
My ping seems quite high, I have been experiencing some lag when playing on the PS4 and PC.
Message 4 of 6
(450 Views)
23-04-2015 11:38 AM
Hi, is your HH5 a Type A or Type B?
The increase in latency is reasonable consistent with interleaving being applied on the line, possibly due to noise / errors.
Crosstalk is often a factor in decreasing FTTC speeds as more subscribers connect to the cabinet they can interfere a bit with each other's lines.
Call me 'w23'
Message 5 of 6
(450 Views)
23-04-2015 1:34 PM
Hi Mada,
If, as you state in your post, your download speed at night is down to 5Mb, it would be advisable to carry out some BT wholesale speed tests and raise a fault, quoting the results. Unfortunately looking through recent forum postings, it appears that many users are currently experiencing similar problems, myself included.
Mike (edgeways)
Mike (edgeways)
Message 6 of 6
(450 Views)
