Fibre Router Not Arrived
- Fibre Router Not Arrived
- « Previous
- 1
- 2
- Next »
Re: Fibre Router Not Arrived
15-06-2018 4:11 PM - edited 15-06-2018 4:35 PM
Unfortunately it won't connect to the Internet.
After the boot procedure, the power light stays flashing orange. The broadband light is off (it goes red if I disconnect the DSL cable). I have restarted the router several times.
I started the router's in-built troubleshooting tool from my PC. It says it can't connect to broadband. It also incorrectly states that the broadband light is red - in reality the broadband light is off.
The troubleshooter says it can take up to 24 hours for the broadband to connect. So for now I will just leave the router switched on and pray!
I have left the username as the default "setup@plusdsl.net".
If anyone at PlusNet technical support can do a check on the line to make sure everything looks OK, it would be much appreciated.
15-06-2018 5:21 PM
If you don't get a reply here - and so far the team haven't pick this up - then report this as a fault.
15-06-2018 5:23 PM
15-06-2018 5:37 PM
Forum only works for problems when it is an issue that other users can help with, or one of the Plusnet team pick it up (and they are quite active, as you will have seen).
Normally the best way to report a fault is using the online system but you haven't got a connection so that is out. It may have to be a phone call but (depending on what you are using to post here) the chat system may offer an alternative. Try going to https://www.plus.net/help/chat/
15-06-2018 7:16 PM
Plusnet router arrived today.
16-06-2018 12:09 PM
18-06-2018 9:04 AM - edited 18-06-2018 9:09 AM
Thanks MatthewWheeler.
I have Question #176839191 open to deal with this broadband fault.
A BT OpenReach engineer arrived at my house at around 8am on Saturday 16/06/18. After some extensive testing, he found several problems relating to our broadband. He performed some work on this issue, but said that further work would be required. We agreed he would come back at a later date to do more work.
In my open Question I have asked for PlusNet to contact OpenReach and ask for an engineer to come back to my house as soon as possible. Our Internet connection has been down for several days and it would be great if we could it working again ASAP.
18-06-2018 9:45 AM - edited 18-06-2018 9:45 AM
I've just had a call from a different BT OpenReach engineer. He's on his way to my house now.
Fingers crossed he can get us back online today!
Thanks once again to everyone who has helped me with this issue so far.
18-06-2018 11:28 AM
18-06-2018 3:38 PM
Hello @Chopmallion,
Thanks for getting back to us. We can see that we are moving you to ADSL as recommended by the engineer. We will need to wait for this order to go through and see how the connection operates at that point.
05-07-2018 9:11 AM
Even ADSL at 4km is marginal.
- « Previous
- 1
- 2
- Next »
