Fibre Download speeds - what should I expect?
- Fibre Download speeds - what should I expect?
02-01-2020 10:29 PM
Hi, was downloading a game and it was downloading at 3 MB/s per second on a line that speed test by BT gives at 24mbps.
Steam is downloading at 2.5MB/s
Is this what I should be expected for my line? Im on Unlimited Fibre Extra
I understand Mbps and MB/s are different, I was wondering whether the speeds i was getting were appropriate for what im paying and the lines i have.
PC is directly plugged into router which is directly plugged into main phone socket.
Cheers
Andy
Re: Fibre Download speeds - what should I expect?
03-01-2020 1:30 PM
Hi @AndyinBrum,
Based on the information you've provided the download speeds are in line with your throughput speeds, but the throughput speeds you're receiving are lower than what they should be, and below the minimum guaranteed line speeds we advised.
I've raised a fault on your service here, before we go down the route of an engineer under the minimum speed guarantee can you confirm that there's no extension cabling in place, and would it be possible to get a speed test with the router plugged into the engineer test socket. The test socket is located behind the faceplate of the master socket and can be access in a number of ways depending on the master socket type you have. If you're unsure how to get to it please feel free to provide us with a picture of the socket and we'll be able to advise better.
03-01-2020 2:10 PM
this is the socket its plugged into
03-01-2020 2:11 PM
also, ethernet to router, direct cable to socket, new microfilter installed when router arrived
03-01-2020 2:13 PM
wifi to router via iphone 17mbps
03-01-2020 6:15 PM
