FAO: CRT -- ECI Modem Latency Problem with G.INP
- Re: FAO: CRT -- ECI Modem Latency Problem with G.I...
Re: FAO: CRT -- ECI Modem Latency Problem with G.INP
27-05-2015 9:34 AM
At least as far as latency goes.
Troubleshooting: The Limitations of Traceroute & Ping
Latency: Connection "fast" but internet sluggish? Bufferbloat FAQ
Black Holes: Worth noting that the Plusnet Hub One router has an MTU of 1488 bytes.
27-05-2015 2:17 PM
3Mb FTTC
27-05-2015 7:00 PM
Quote from: godsell4 FTTC install last week, it was a BTO Engineer, he only had ECI modems and we have a Huawei cabinet.
I recently had an Openreach engineer looking at my line (ECI modem with G.INP enabled - lost 15Mbps) He only had ECI modems as well, when I asked him about Huawei, he said they're no longer being issued with them, just ECI modems.
As an aside, he said if I did get hold of a Huawei HG612 then make sure it was a 3B, apparently the 2B's overheat and there had been rumours of some catching fire
29-05-2015 6:46 PM
I do wish they'd leave my line alone.
It was back to 80 Mbps sync yesterday after PlusNet got them to fix the line fault caused by doing an installation at a neighbouring property.
Hurray! Well done PlusNet
Three weeks of effort went into that result.
It meant the residual G.INP effect was then clearly visible.
But today Openreach themselves (not sub-contracted to Quinn this time) have done another installation at another neighbouring property... and messed it up even more impressively!
BT IP Profile is down to 25.18 Mbps now
At least it means the BT Wholesale network problems aren't so visible, I suppose!!!
(Yes, the BTw peak time packet loss never completely went away.)
And G.INP... well, that pales into insignificance. That was only an 11.61 Mbps loss. Now we're talking about a 52.17 Mbps reduction in BT IP Profile from normal service, the line can't even support the PlusNet 40 Mbps package any more. Definitely service-affecting now: to a greater degree, both in percentage and absolute terms, than G.INP incompatibility on a good line with the 80 Mbps package!
So tiresome.
I think it's about time BT were forced to sell Openreach off, personally. But that could just be irrational, stunned frustration talking...
29-05-2015 9:16 PM
30-05-2015 11:36 AM
30-05-2015 3:48 PM
As chrcoluk says, bad is good in a way: at least they can't say it's working within acceptable parameters!
And if needs be, my neighbour can probably get a copy of the engineer's notes from his ISP. So this time a named individual, directly employed by Openreach, can take responsibility.
Go back a few months and I didn't have to concern myself with my internet connection at all.
That's what I want to get back to...
It's how life should be!
The annoying thing for PlusNet is that all of this bother is being caused by your supplier, but you end up having to deal with the fall-out. So I am grateful for the time and effort needed to do that.
10-06-2015 11:36 AM
Will be two weeks on Friday.
10-06-2015 3:47 PM
The fault was stuck on our suppliers systems but it has come back now.
They're wanting to arrange a engineer to the property investigate further. We can try and push back to get a engineer to investigate externally but this may delay things by a couple of days.
10-06-2015 4:58 PM
With every ISP nationwide now issued with the new profile for removal of G.INP on the upstream, what should I be seeing, because nothing seems to have changed my side with speed or latency.
I might be wrong, but I was expecting this new profile would trigger a re-sync, therefore also changing my PPP session and giving back the lost 11 Mbps and sub 10ms ping.
Any chance you could see if my line does show the updated profile and if so, should I reboot my router or even restart the modem.
Thanks.
10-06-2015 6:03 PM
As far as I'm aware the profile changes are being gradually rolled out and not all at once.
With regards to the change you are correct as your line should resync.
Your current profile is "0.128M-80M Downstream, Retransmission Low - 0.128M-20M Upstream, Retransmission Low"
10-06-2015 10:31 PM
To be clear though, the profile update only removes the automatic application of upstream interleaving, where a line does not support retransmission in the upstream. It does not disable retransmission on lines that are capable of supporting it on the upstream.
11-06-2015 11:25 AM
Quote from: AndyH
This depends on what, a consumer equipment (ie, modem or modem/router)?
11-06-2015 11:31 AM
11-06-2015 11:35 AM
